Compiler problem PIC 18F4450
pilot321
Post by pilot321 »
HI
I have a basic license for 8 bit PIC, and BL0080 and BL0011 programmer boards. I have compiled programs successfully to the 16F18877 supplied with the boards.
I have written a program for the 18F4450 chip, but when I try to compile this chip I am unsuccessful. I have attached a screenshot,
could you please advise me how I can compile this chip?
Thanks.
Screenshot (4).png (173.13 KiB) Viewed 4654 times
kersing
Has thanked: 553 times
Been thanked: 1081 times
Re: Compiler problem PIC 18F4450
Post by kersing »
Does your flowchart contain C code to set the oscillator settings?
― C.S. Lewis
The issues are within configuration settings i.e Build, project options, configure.
You will need select the correct oscillator type and change Extended CPU Enable to Disable.
You will be best going over all the options e.g Watchdog Time to disable etc.
pilot321
Post by pilot321 »
Thanks for getting back to me.
I am not using C code to configure the oscillator, but I have disabled the extended instructions and watchdog timer, and the chip is now compiling.
I am still getting the following warning. ^ (1386) unable to determine the semantics of the configuration setting "FOSC" for register "CONFIG1H" (warning)
I will have another go tomorrow, when I have time.
Thanks again.
pilot321 wrote:
Tue Nov 17, 2020 9:58 pm
That issue I covered by
medelec35 wrote:
Tue Nov 17, 2020 9:17 pm
The default oscillator type is 15, which is nonsensical.
You will need to select HS,XT internal etc.
pilot321
Post by pilot321 »
Hi Martin
I have changed the Oscillator settings from 15, and tried various combinations of Oscillator types, clock speeds and divide values.
I have managed to flash an LED at approximately I second intervals, but not exactly, also I have tried to display text on the LCD, but to no avail.
Ultimately I want the 18F4450 chip to drive the W5500 ethernet module.
Do you know how I could set the Oscillator settings to get this chip to work correctly?
P.S
I am using the BL0080 board and eblocks boards.
Thanks.
Here is a file that is preconfigured for the 18F4450 hopefully the display should work and you should get port A flashing on and off with delays of 1 second confirming all the timings are correct.
Demo18F4450.fcfx
(8.26 KiB) Downloaded 248 times
pilot321
Post by pilot321 »
Thanks for the demo program, I have it running, hopefully I will be able to progress.
Thanks for your help.
