SDI/MISO pin in DAC application
Posted: Thu Dec 09, 2021 2:02 pm
Hello!
good evening
I am using MCP4921 DAC, communicating with PIC on SPI, one of the connections mentioned in the properties window is SDI/MISO (pin C4 in channel 1 of chip PIC18F26K22), may i know if it is possible to use this pin for other application as it is not connected or not used as no data is received from DAC to PIC. I notice this particular PIC do not have remap able pins so i cannot select "unused" or something similar.
Is there any way to use that pin, it is resting for the moment
Thank you.
Abhi
good evening
Thank you.
Abhi
