C icon with asm code
psf
Has thanked: 6 times
Been thanked: 2 times
Post by psf »
Using Flowcode 7 with a simple c icon:
ASM sleep
is not compiled.
If I use flowcode 6 OK. The complier is different and slower but works. what about?
Bachman
Has thanked: 9 times
Been thanked: 53 times
Re: C icon with asm code
Post by Bachman »
Try:
SLEEP();
or
Sleep();
psf
Post by psf »
Yes, I know, but why should I use c if the description give also asm code?
Bachman
Post by Bachman »
Because nothing to optimise on a simple instruction and doesn't matter, what you're using, C or ASM.
_asm
    sleep
_endasm
or
asm("sleep");
or
_asm sleep _endasm
psf
Post by psf »
_asm
movlw 0x88
movwf _intcon
movlw 0x06
movwf _ioc
sleep
nop
_endasm
809: _asm
^ (195) expression syntax
EXAMPLE.c:
921: mainendloop: goto mainendloop;
^ (374) missing basic type; int assumed (warning)
^ (314) ";" expected
922: }
^ (285) no identifier in declaration
(908) exit status = 1
Bachman
Post by Bachman »
With Flowcode 7 and above XC8 compiler is used instead of BoostC
Therefore, what works with V6 assembly won't work with V7+
For example SFR must be in upper case.
In your case you can try
#asm
movlw 0x88
movwf INTCON
movlw 0x06
movwf IOC
sleep
nop
#endasm
nop and sleep are not directly assembly, therefore
NOP
and
SLEEP
should also work.
What target device are you using?
psf
Post by psf »
Perfect, now asm block works and compilation in XC compiler is 1 seconds long instead of >1 min od boostC
That's great.
Thank you for letting us know.
The advantages of XC8 are compile speed and regularly updating with newer targets.
