ESP32 support
Posted: Sat Feb 04, 2023 1:29 pm
by jadiflow
Hi, getting up to speed with the ESP32 family.
I want to develop hardware with WiFi, USB and Ethernet support.
Espressive has what they call the ESP32 Ethernet board https://docs.espressif.com/projects/esp ... 1-2-layout, which has Ethernet functionality as well as the WROVER WiFi/Bluetooth plugin board.
Flowcode has support for the WROVER module, but I am not sure whether the combination with the Ethernet board is supported.
How would I use that board in FC?
Jan Didden
Re: ESP32 support
Posted: Sat Feb 04, 2023 2:52 pm
by chipfryer27
As far as I am aware that particular board is not directly supported. However as ESP support started with v9 it may be better if you post your question in the v9 forum as perhaps someone has used it and can advise better.
Re: ESP32 support
Posted: Sat Feb 04, 2023 3:14 pm
by jadiflow
Thanks, but as far as I am aware I did post in the FC9 forum, but I will check.
I started using FC with version 5, so I am always shown as FC5 user ...
Maybe the system automagically slotted me into the FC5 forum, I don't know.
Edit - I see, the FC9 forum is a whole different board section. Thanks for correcting me!
Jan
