Example circuits
Posted: Wed Jul 25, 2007 12:39 pm
by Peter
I've programmed a 16f88 ready for my first project and it's working fine on the multiprogrammer board. Now I need to transfer it to a real circuit, but I could do with some examples of circuits so that I know what else has to go onto the PCB with the PIC. At this stage I need something really simple - e.g. timing is not critical so maybe I could manage without a crystal.
Could anyone direct me to some simple circuits that I could learn from?
Many thanks
Posted: Thu Jul 26, 2007 9:11 am
by Steve
Microchip have many application notes that may help.
Also, the circuits for our E-Blocks boards are available in the datasheets here:
http://www.matrixmultimedia.com/eblocks/index.php
Posted: Thu Jul 26, 2007 10:14 am
by Peter
Thanks Steve. Those are two of the sources I checked out before posting my request - sorry, I should have said that I had been doing some looking around first.
The E-blocks ciruit diagram are invaluable for designing the peripheral electronics but they don't show the actual microprocessor (no reason why they should - it will normally be on a different board). As far as I can see, the Microchip examples don't cover the 16f88. I guess I could adapt the 16f877 examples but they all seem quite advanced, whereas I'm looking for something really simple.
I have desined a simple controller to do a small job in the house: a relay in another bit of equipment flicks on and off and this will send a signal to the PIC to do various combinations of switching a motor and indicator lamp. Conditioning the relay signal and controlling the motor and lamps is dead easy but sorting out what timing and other circuitry I need around the PIC is proving a tad difficult for an absolute beginner to pin down.
For example, if I choose not to use a crystal do I need an external RC circuit and where should it go? Are there some pins on the chip that must be grounded? do I need a reset switch? and so on.
So if you or anyone else knows of a good internet source of this sort of advice, or a good book, even, I would be very grateful to hear of it.
Posted: Thu Jul 26, 2007 10:27 am
by Steve
Our EB006 datasheet should include the microcontroller's power, reset and oscillator circuitry.
Also, Microchip's datasheet for the 16F88 contains some example oscillator circuits.
For the basics, you need to make the following connections:
* Vdd = +V (probably 5V)
* Vss = GND
* MCLR = +V via a 10k resistor (+ optional 'reset' switch to GND)
The '88 has an internal oscillator, so you do not need an external RC circuit - especially is your program timing is not critical.
Hope this helps.
Posted: Thu Jul 26, 2007 11:13 am
by Peter
It helps a lot - just what I needed to know. Thanks, Steve, you're a star!
