Version 3 Development board and 8 pin PIC's eg 12F675
Posted: Wed Nov 22, 2006 12:24 pm
As you may expect when using an 8 pin PIC I would like to have access to the gretest number of I/O pins. To do this I presumably need to use the internal 4Mhz clock and no MCLR.
As the Version 3 board is wired can I actually 'remove' the clock input?, I can go down to 1 pin with the R/C oscillator or would an option be to configure for the crystal oscillator and remove the crystal?
As for MCLR can I take it that the MCLR switch will simply act as an input switch when the PIC is not configured to use MCLR?
Any thoughts on the above will be welcome.
As an alternative I can use a PIC KIT 1 board for programming but my first thoughts are to stick with Dev Board 3 for ease of interface with Flowcode.
