Com port monitor global edition
Posted: Tue Nov 20, 2007 12:22 am
by elvand
Comport monitor is a simple and useful application monitoring PC-RS232 (COM) port .You can sent and receive bytes with this application . Also you can see bytes received in hex/bin/decimal format and sent as decimal/string format.
FEATURE :
Auto detect your PC available Com ports.
Change transfer baud rate between 1200-19200 .
Change parity / stop bit / byte size and packet size manually.
Events on CTS/DSR.
Define end of line .
Exchange Hexadecimal , Binary , Decimal to them.
Sending data to port using string mode or decimal ( character ASCII code ) mode.
Receiving data from port in Hex/Dec/Bin mode.
Free to use.
See more information on :
http://www.elvand.com
