EEPROM Storage
Posted: Thu Jan 10, 2008 7:01 pm
by Gnu
Is it possible to store the 10-bit output from the ADC in a 16F88 in its EEPROM, using Flowcode, perhaps by storing 5 bits in two separate locations ? If so, what is the neatest way of getting the number out again ?
IRH
Posted: Fri Jan 11, 2008 10:25 am
The easiest way is to use a full two bytes. eg 16-bits.
Firstly you will have your 16-bit integer variable, we will call this int_var.
So to convert int_var into two bytes we do the following.
byte1 = int_var
byte2 = int_var >> 8
The two bytes can now be written to the EEPROM or the RS232 etc.
To convert the number back simply reverse the calculations.
int_var = byte1
int_var = int_var + ( byte2 << 8 )
Posted: Fri Jan 11, 2008 10:36 am
by Gnu
Thanks Ben.
Gnu
