C for ARM Vista Not...
Posted: Tue May 06, 2008 5:46 pm
by LinkerDude
When I install your software package "C for ARM Microcontrollers" it looks like it installs well, but when I compile the first example I gett the following message:
> "make.exe" all
-------- begin --------
arm-elf-gcc (GCC) 4.0.1 (WinARM)
Copyright (C) 2005 Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
Assembling (ARM-only): ../Global/Cstartup.S
arm-elf-gcc -c -mcpu=arm7tdmi -I. -x assembler-with-cpp -DROM_RUN -Wa,-adhlns=../Global/Cstartup.lst,-gstabs ../Global/Cstartup.S -o ../Global/Cstartup.o
arm-elf-gcc: installation problem, cannot exec `cc1': No such file or directory]
make.exe: *** [../Global/Cstartup.o] Error 1
> Process Exit Code: 2
I tried this on my XP machine and there it works just fine.
Not so on my Vista machine.
I have tryed to instal it as an administrator as I know that Vista can apply security measures that can affect some installations not to include everything but to no success.
Do you have a install package that you know that it work on vista that you can provide to me?
Or, do you have a quick fix to my issue?
Best Regards
LinkerDude
Re: C for ARM Vista Not...
Posted: Fri May 09, 2008 4:59 pm
by Sean
In XP, the GCC compiler searches some default locations to find the files it requires. Vista seems to prevent GCC from performing this automatic search operation, so a number of additional paths must be added to the Vista environment, or to the tool chain command lines.
The main GCC installation directories that must be added to the Vista path list are:
\bin
\libexec\gcc\arm-elf\4.0.1
\arm-elf\bin
The compiler command line requires the paths to the following GCC installation folders to be supplied as a cpath command:
\arm-elf\include
\lib\gcc\arm-elf\4.0.1\include
The linker command line requires the paths to the following GCC installation folders to be supplied using a -L directive for each one:
arm-elf\lib
There are several ways to implement these changes for Vista. We hope to be able to release an upgrade that will automate the process in the near future.
Posted: Fri May 09, 2008 10:34 pm
by LinkerDude
I tried to add the paths to the system path by navigating through:
Control Panel->System->Advanced settings->Environment Variables, and selecting Path and edit that by adding the path mentioned.
Naturally the full path for example:
………..;C:\Program Files\Matrix Multimedia\libexec\gcc\arm-elf\4.0.1\;………..
Well, the cc1.exe is in one of your path but still it can’t be found.
Oh, and I restarted my computer to be sure that the newly added path would be included.
I admit that I’m far from a path guru so maybe I’m missing some basic knowledge here.
First I tried a .bat file but my skill is apparently not as developed that I could managed that as that did not show up in the Environment Variables. (Maybe new rules for Vista. I don’t know. I even executed that bat file as an administrator by right-clicking the bat file on my desktop).
Maybe if you can create a working .bat file that puts all together you could provide that trough this webboard?
The beginning of the path name may be different from different countries but I use an English OS.
For instance in on a Swedish Vista OS the folder “Program files” are spelled different.
Best Regards
LinkerDude
Posted: Sat May 10, 2008 10:03 pm
by LinkerDude
Weeee, I just got it to work.
For others to know:
I just added this to my path variable:
;C:\Program Files\Matrix Multimedia\WinArm\libexec\gcc\arm-elf\4.0.1;C:\Program Files\Matrix Multimedia\WinArm\arm-elf\bin;C:\Program Files\Matrix Multimedia\WinArm\bin;C:\Program Files\Matrix Multimedia\WinArm\utils\bin;
Now it works.
Best Regards
LinkerDude
