Development Board HP-488 (Version 3?)
Posted: Wed Sep 24, 2008 11:31 am
Hi Guys,
The MCLR Reset is not working on the board. the switch is fine but the board is not delivering 5v to the MCLR pin (on any socket). It seems to be not connected as some chips leak enough current to bring it up to around 3v in which case the chip works. Any suggestions? (J29 for Power/USB looks OK).
Where is R12 (the pull up resistor?) on the board, or is it not labelled?
Could you send a clear schematic of the board (the one on the data sheet is unclear) so I can try and diagnose the problem?
Thanks,
Mark
Thanks,
Mark
