PB with flowcode v3 and LCD on matrix card
itti
Post by itti »
hello,
I have some problems with Flowcode V3 and the LCD.
The simulation is OK but when i send the program in the matrixcard, the LCD do'nt work.
It's OK with LED or LED7seg1 and the card is OK with flowcode V2.
I try with PIC 16F84 and 16F877.
I try with the example, and my own program.
I try to with severall cards.
Is there a problem with the routine (with V2, we used macro)?
Thank you for your help, sorry for my english (i'm french).
Γ©ric
Re: PB with flowcode v3 and LCD on matrix card
It could be one of the following reasons:
  1. You have not initialised the LCD with the "Start" macro
  2. The connections to the LCD are not specified correctly
  3. The clock speed set in Flowcode is not set the the actual processor speed
  4. The configuration word settings are inappropriate (e.g. wrong clock type, watchdog is on, LVP is on)
itti
Post by itti »
thank you for the answer, I have seen that the problem is only with Vista.
I try with a PC with windows XP and flowcode V3 and it's OK.
But some program are OK too under vista like program with led or led7seg!!!
The PB is only with lcd; I have found this error message in code C:
void FCD_LCDDisplay0_Start()
//Error Reading Code For Afficheur LCD::Macro_Init
Γ©ric
Flowcode2.fcf
(3.5 KiB) Downloaded 319 times
It looks like the C code file for the LCD has been altered and cannot be read correctly. Please try copying the LCDDisplay_Code.c file from the XP PC to the Vista one and then re-launch Flowcode.
itti
Post by itti »
Yes! thank you, that's OK!
Nevertheless, I'm surprise because I used the same Cd for the installation on my new computer.
The own diffΓ©rence:On the old computer, I had the two version V2 and V3.
thanks again
Γ©ric
