discerning between two square waves
Posted: Wed Jan 07, 2009 5:53 am
I am building an application, based on the ECIO40P, which will need to discern between the following two square waveforms:
1: 425hz Mod @ 25hz, 0.4 seconds on, 0.2 seconds off,0.4 seconds on,2 seconds off, REPEATED
2: 425hz 0.4 seconds on, 0.4 seconds off, REPEATED
These patterns are a ringing and busy/disconnect signal respectivly, as presented by the call progress output of a Mitel MT8880c DTMF transciever. I currently have this connected to RA4 of the ECIO.
Ideally I would like to be able to differentiate between the two but at the very least I need to be able to ignore the first wave form (ringing tone) and react to the second (disconnect).
I have no idea where to start so any and all advice will be greatly received.
MW
MW
