With the ECIO application board , can it be powered by running wires to the screw terminals from the V3 development board terminals. I run the V3 board from the power supply supplied by yourselves.
Or if not, can I parallel the output of the PSU to both boards.
This is for example using the ECIO and dev boards to communicate with each other using something like the Infared or Bluetooth E Blocks
ECIO
Re: ECIO
John
Yes the ECIO can be powered from any 5V source. Use the terminals marked +v on the V3 Development board.
Gilbert
Sorry not sure what you mean by libraries for eagle. Do you mean the CAD for the ECIO circuit board.
Gilbert
Re: ECIO
In Flowcode you can click on View -> Chip to see the pin connections of the ECIO device. The ECIO datasheet is also available from the product page which details the pin connections.
Hope this helps.
Hope this helps.
