Resolution of INT
Posted: Wed Apr 08, 2009 11:14 am
I am after a simple formula to calculate resolution of INT at 5V
E.G. if 8 bit Byte type, Resolution = 5/255 = 0.196
So If ADC I/P = 3V then Value = 255/5 x 3 = 153
So what number do replace 255 with if using INT instead of BYTE please?
Is it 16 Bit 65536 which = 5/65536 = 76 Microvolts?
So if 3V is used again. Value = 65536/5 x 3 =39321
If this is correct, is 39321 going to be actual value assigned if ADC I/P is 3V?
Update: I have just rembered: If using ADC within Flowcode then max bits = 2y10 = 1024
therefore 3V would give 1024/5 x 3 = 614.
Am I correct?
Re: Resolution of INT
Posted: Wed Apr 08, 2009 4:02 pm
by Steve
almost - 1023
