I'm trying to activate the internal A-reg weak pull-ups in an 16F684. I have the following C-code block:
//enable weak pullups
//C Code:
option_reg = option_reg & 0b01111111; //enable wpua
//weak pullup on A
//C Code:
wpua = 0b00110111; //wpua on all
The wpua... line generates a compiler error. I checked the 16F684.fcd and didn't find anything on the weak pullup register. Is this not implemented in the F684?
Thanks,
Jan Didden
16F684 weak pull-ups?
kersing
- Has thanked: 553 times
- Been thanked: 1081 times
Re: 16F684 weak pull-ups?
Jan,jadiflow wrote: wpua = 0b00110111; //wpua on all
It looks like it is called WPU, not WPUA in the definition for this processor.
Good luck,
Jac
― C.S. Lewis
― C.S. Lewis
Hello Jan
The registers are defined in the BoostC/Include files rather then the FCD files. These are more for configuring Flowcode for the chip rather then configuring the compiler.
