secret doorbel
Posted: Tue Jun 16, 2009 11:12 am
by jacobsg
Is it possible to add two or more different secret codes to arm the secret doorbel in the book microcontroller systems engineering? if possible could you guide me to what I need to do.
Gerhard Jacobs
Re: secret doorbel
Posted: Tue Jun 16, 2009 1:18 pm
Hello Gerhard
If you look at the program you will find a string comparison that is done using a string manipulation icon. The result from this is then used to drive a decision icon which decides whether or not to do a task. You should be able to add more keys by copying the comparison and decision code and simply comparing against different keys.
Re: secret doorbel
Posted: Tue Jun 16, 2009 8:00 pm
by jacobsg
thanks. I am new to flowcode and battle with the technical names, could you be more specific as to where the string is
Gerhard
