doorbel
jacobsg
Has thanked: 2 times
doorbel
Post by jacobsg »
This is a question I have from your microcontroller system engineering book, secret doorbel programme page 48. I have altered the programme (not for commercial use) I am trying to learn and understand the use of flowcode and string manipulation. The programme works perfectly except for the following: I have changed the display on the lcd. The 2 number code is now displayed on line 0,1. However only the first digit display and every subsequent digit is printed over the previos one. How can I change the display so that the two digits both display on line 0,1 next to each other. I attached a pdf flowchart for you to see.
Gerhard
practice1.pdf
(16.32 KiB) Downloaded 389 times
Sean
Has thanked: 6 times
Been thanked: 44 times
Re: doorbel
Post by Sean »
Your program appears to control the cursor, or clear the display, after every keypress. I can not see all the details from the pdf image, but if the cursor command always puts the cursor at 0,1 then each character will always overwrite the previous one.
You can use variables with the cursor control macro to place the cursor at calculated positions, or use decision blocks to bypass the cursor command when you want the auto-increment feature of the LCD to put characters in adjacent locations.
If you want to print two single digits, only use the cursor command for the first digit, or use a digit counter as the x variable to position the characters.
