Parameters in customised code
Posted: Mon Jul 13, 2009 3:18 pm
by Dan81
I'm trying to move customised code (DMX Master) from Flowcode3 to Flowcode4.
One of my functions needs 9 parameters but I can only declare 6.
Is there a way to add the other 3.
Thank you
Daniel
Re: Parameters in customised code
Posted: Wed Jul 15, 2009 7:59 am
by Dan81
I've forgotten to specify that I use RS232_Component and that I create a new macro in the component properties.
I do not modify "RS232.c"
If the number of parameters could be raised to 10 (like local variables) that would be very nice.
Thank you
Daniel
Posted: Wed Jul 15, 2009 8:54 am
Hello Daniel
If you need 10 parameters for your macro then you can define a single parameter as param[10] and then reference in your program by using macro.param[0] to macro.param[9].
Hope this helps.
