V4 and windows7 xp_mode
Posted: Sun Sep 06, 2009 8:02 am
by saschech@gmx.de
Hello Steve,Benj,Sean
In windows7 there i cannot read the v4-help,so I install v4 on the virtual-xp.
If i want compile,i receive the Error:
Do you no why?
Regards Wolfgang
Re: V4 and windows7 xp_mode
Posted: Mon Sep 07, 2009 8:45 am
Hello Wolfgang
It could be some kind of permissions problem. Check you have the correct read and write priviliges for your project directory.
I am running Windows 7 also and can run help files by opening the Windows.001 old folder from my previous Vista install. In here there is a Windows folder and in here there is the WinHLP32 file. If you drag a help file onto this version of the Windows help then the file will open correctly.
If you did not install windows help when you were running Vista then I dont think there is much you can do other then to use the XP. I have not tried this so if you make any progress please let me know.
Posted: Mon Sep 07, 2009 12:16 pm
by saschech@gmx.de
Hello Benj
If my *.fcf file in a network-place i become nearly the thame error.
On these place i have guaranteed all rights.
Regards Wolfgang
Posted: Mon Sep 07, 2009 12:34 pm
by fresh
The winhelp32.exe from Windwos XP System also running under Windwos7.
If Windows7 Final is out, than you con download the new winhelp32.exe by microsoft
