I tried to install the CD on Windows 7, but the program neuron65.exe fails. Despite of a provided hyperlink (is not working), I cannot find an upgrade and installation fails. The rest works fine.
Next I tried to run the program in a virtual machine (XP). Now the install works fine, exept the build in copy protection. It needs to check the presence of the original cd. This fails because the architecture of the virtual machine.
Is there a solution or workaroundf?
Robotis & Megatronics CD on Vista/Windows 7
Re: Robotis & Megatronics CD on Vista/Windows 7
There are newer versions of the ToolBook Neuron plugin available for download from here.
http://www.sumtotalsystems.com/support/ ... euron.html
You must ensure that your internet browser is closed before trying to install. If your browser is still running then the installer will report success but the Toolbook plugin will not run correctly.
- Been thanked: 1 time
You can Upgrade smoothly by finding the correct drivers for your hardware and software for any version of windows..!
