ECIO cannot be installed.
Posted: Mon Nov 23, 2009 5:48 am
by achillis1
I have two ECIO 40P and I was working with one of them some days ago and it was working fine. Today I am trying to connect the other one and the operating system could not install the new hardware! I tried to install again the drivers but again nothing happend. Then while the ECIO was connected on my laptop I pushed for more than 5 seconds the reset button. After that the ECIO just keep blinking and nothing happens. I would have tried to connect the other ECIO to see what happens but I have sent it to my programmer to test it with some software I am developing.
Have you got any ideas?
Thank you in advance,
Best Regards,
Achillis
Re: ECIO cannot be installed.
Posted: Mon Nov 23, 2009 7:51 am
by Steve
Have you tried to restart your PC? Or tried it on a different PC?
Also, is the ECIO module showing in the "device manager" page of Windows. If it is, you might be able to "remove" the ECIO device (i.e. uninstall its drivers) and start the installation process again.
Also, there are a number of 3rd party driver installation helpers that might help fix this problem. One that I have heard of is "chilli driver" or something similar (but I have never tried it, so I don't know if it works or not).
Posted: Mon Nov 23, 2009 10:49 am
by achillis1
Thank you for your reply.
Yes, I have restarted my PC several times but nithing happended(yesterday). Today I did the same procedures as yesterday and the ECIO has been installed correctly!!!
But something else now has been appeared. When I connect the ECIO to my pC then it flashes for a 3 or 4 seconds and then it is OK. When I try to compile and send the program to the ECIO then two different events will occur: A: The program will compile and successfully transferred to the ECIO; but the ECIO's LED will infinitely keep flashing.
B: the software while compiling to show the following error and the ECIO's LED again infinitely fashing:
" Launching the compiler...
C:\Program Files\Matrix Multimedia\Flowcode V3\BoostC\boostc.pic18.flowcode.exe -v -t PIC18F4455 "RTC TEST ANDREAS.c"
BoostC Optimizing C Compiler Version 6.70 (for PIC18 architecture)
http://www.sourceboost.com
Copyright(C) 2004-2007 Pavel Baranov
Copyright(C) 2004-2007 David Hobday
Licensed to FlowCode User under Single user Pro License for 1 node(s)
Limitations: PIC18 max code size:Unlimited, max RAM banks:Unlimited
RTC TEST ANDREAS.c
Starting preprocessor: "C:\Program Files\Matrix Multimedia\Flowcode V3\BoostC\pp.exe" "C:\Users\matrices\Desktop\temp\RTC TEST ANDREAS.c" -i "C:\Program Files\Matrix Multimedia\Flowcode V3\BoostC\include" -d _PIC18F4455 -la -c2 -o "RTC TEST ANDREAS.pp" -v -d _BOOSTC -d _PIC18
RTC TEST ANDREAS.c success
success
Return code = 0
C:\Program Files\Matrix Multimedia\Flowcode V3\BoostC\boostlink.pic.exe -rb 0x800 -ld "C:\Program Files\Matrix Multimedia\Flowcode V3\BoostC\lib" libc.pic18.lib flowcode.pic18.lib "RTC TEST ANDREAS.obj" -t PIC18F4455 -d "C:\Users\matrices\Desktop\temp" -p "RTC TEST ANDREAS"
BoostLink Optimizing Linker Version 6.70
Warning unreferenced functions removed:
FCD_I2C0_GetDefines in: C:\Users\matrices\Desktop\temp\RTC TEST ANDREAS.c
FCD_I2C0_MI2C_Stop in: C:\Users\matrices\Desktop\temp\RTC TEST ANDREAS.c
FCD_LCDDisplay0_GetDefines in: C:\Users\matrices\Desktop\temp\RTC TEST ANDREAS.c
FCD_LCDDisplay0_Clear in: C:\Users\matrices\Desktop\temp\RTC TEST ANDREAS.c
FCD_LCDDisplay0_PrintASCII in: C:\Users\matrices\Desktop\temp\RTC TEST ANDREAS.c
FCD_LCDDisplay0_Command in: C:\Users\matrices\Desktop\temp\RTC TEST ANDREAS.c
FCD_LCDDisplay0_RawSend in: C:\Users\matrices\Desktop\temp\RTC TEST ANDREAS.c
FCD_LCDDisplay0_Cursor in: C:\Users\matrices\Desktop\temp\RTC TEST ANDREAS.c
MI2C_Dummy_Function in: C:\Users\matrices\Desktop\temp\RTC TEST ANDREAS.c
LCD_1377016_Dummy_Function in: C:\Users\matrices\Desktop\temp\RTC TEST ANDREAS.c
Building CASM file
Memory Usage Report
RAM available:2048 bytes, used:22 bytes (1.1%), free:2026 bytes (98.9%),
Heap size:2026 bytes, Heap max single alloc:127 bytes
ROM available:22528 bytes, used:1338 bytes (6.0%), free:21190 bytes (94.0%)
success
Return code = 0
Launching the programmer...
C:\Program Files\Matrix Multimedia\Flowcode V3\ECIOprog.exe -nogui "RTC TEST ANDREAS.hex"
File loaded: RTC TEST ANDREAS.hex
USB Write Failed
Failed with error 997: Overlapped I/O operation is in progress.
ECIO-40 version: (????)
Ready
Sending Program...
USB Write Failed
Send Failed
Ready
Return code = 0
FINISHED "
Also tried to reset it several times by pressing the reset button for more than 2 seconds.
Best Regards,
Achillis.
Posted: Mon Nov 23, 2009 3:03 pm
by Steve
Other users have had this problem before. If you search the forums for "overlapped" you will get the following links which should help you solve your problem:
http://www.matrixmultimedia.com/mmforum ... ped#p14015
http://www.matrixmultimedia.com/mmforum ... ped#p10322
Posted: Tue Nov 24, 2009 1:40 pm
by achillis1
I have uninstalled and installed again the drivers. I think that at some point I installed the "old" ECIO drivers, I do not know if that could cause the problem.
Nevertheless, last time I installed the drivers and connected my laptop to power(maybe the ECIO could not drain much power from laptop's USB-due to the fact it was running on battery) the ECIO was successfully installed!!!
Thank you,
Best Regards,
Achillis.
Posted: Tue Nov 24, 2009 1:50 pm
by Steve
Great news!
