speech component
Posted: Fri Jan 29, 2010 8:45 am
by g-slocombe
I have uninstalled and downloaded the full flowcode 4 from support website to try and fix the speech component problem.
but now the speech component in the drop down menu now appears as a seven segment display, there is no speech icon
visible. Any ideas what to do next. I need to get this working because it is used in the teaching laboratory.
cheers Gary
Re: speech component
Posted: Fri Jan 29, 2010 9:56 am
Hello Gary
Did you use any of the beta versions of Flowcode 4 by any chance?
There is a workaround for the problem you are describing available from here.
http://www.matrixmultimedia.com/mmforum ... 986#p15986
Posted: Fri Jan 29, 2010 9:59 am
There is also this file which includes an automatic fix and instructions for usage.
Please let us know how you get on.
Posted: Fri Jan 29, 2010 12:08 pm
by g-slocombe
The workspace fix restored the speech icon on the component drop down.
When I tried the example speech program in examples folder and added enable speech output it works.
But I noticed that the speech properties had a base address of 2520, the suggested base address was 77707. When I selected use suggested base address it does not work. Could this be the problem ? because I am using the suggested base address in my program.
I have added my program as attachment for you to try.
Thanks Gary
Posted: Fri Jan 29, 2010 2:33 pm
Hi Gary
Thats great thanks for letting me know.
Your query about the base address has been sent to the Flowcode technical team and they will let you know the outcome.
Posted: Mon Feb 08, 2010 1:27 pm
by g-slocombe
I added the new speech component to the components directory and restarted flowcode, but still get the same error loading speech macro.
Regards Gary
