Re: usb 232 board communication between two computers
Posted: Wed Feb 17, 2010 11:30 am
Yes the USB232 board should be able to do this no problem. You will have to setup the two boards as follows.
Jumper positions D and 3 on both boards.
Then use single core wire to link the following connections between the boards.
rx - tx
tx - rx
rts - cts
cts - rts
And then you should be up and running.
rx - tx
tx - rx
rts - cts
cts - rts
