Look-up-tables.
Posted: Thu Feb 18, 2010 7:38 am
For my latest project I'm using four LUT's (4 x 50)
Since they are bytes, they only cover 0-255
Is there a way (without doubling quantities of LUT and using: number=LUT x 100+LUTb , e.g. I If number is 2614, then 1st LUT = 26 and second LUT=14) of using a 10bit LUT?. I need to retrieve numbers in the range of 0 to 3274
The only other way I can think of is using int arrays. Since I have made a spread sheet to create and paste LUT data directly into flowcode, I want to avoid arrays if i can.
Re: Look-up-tables.
Posted: Thu Feb 18, 2010 9:18 am
Hello Medelec
You should be able to do something like this.
temph = LUT[pos]
templ = LUTB[pos]
intvar = (temph * 100) + templ
Re: Look-up-tables.
Posted: Thu Feb 18, 2010 10:03 am
Benj wrote:Hello Medelec
temph = LUT[pos]
templ = LUTB[pos]
Thanks for reply Ben. I was after a method which did not require doubling of LUT
is your method same as example I posted which I am trying to avoid?:
medelec35 wrote:(without doubling quantities of LUT and using: number=LUT x 100+LUTb
Am I correct in saying all LUT are 8 bit only?
Re: Look-up-tables.
Posted: Thu Feb 18, 2010 11:32 am
Hello Medelec
Sorry I think I misread,
You can create a 16-bit LUT in Flowcode if you need to by creating a int array though as you suggested this would cause problems initialising the data.
You can also create a C code array by doing something similar to this in the supplementary code window.
int LUT[2] = {1234, 2345};
This would be stored in RAM and would have a maximum size of 128 int variables.
A ROM array can only be 8-bits max.
Re: Look-up-tables.
Posted: Thu Feb 18, 2010 12:55 pm
Thanks Ben. I only said avoiding arrays due to spreadsheet copy and paste. Since you have overcome that with C code, so long as don't go above max RAM capacity, your solution will best way forward!
Re: Look-up-tables.
Posted: Thu Feb 18, 2010 5:17 pm
Ben Should it be:
Problem is I now get following error message:
m:\NEW_HIGH_EFF_HR_V3_BASIC1B_EBM_Fans.c(209:223): error: too many initializers
m:\NEW_HIGH_EFF_HR_V3_BASIC1B_EBM_Fans.c(209:26): error: failed to initialize variable 'FCV_STD155_RPMF1'
m:\NEW_HIGH_EFF_HR_V3_BASIC1B_EBM_Fans.c(211:220): error: too many initializers
m:\NEW_HIGH_EFF_HR_V3_BASIC1B_EBM_Fans.c(211:26): error: failed to initialize variable
If declared in supplementary window, does that mean if variable is added which has the same name, causes the above error?
If that is the case then that would mean assigning variable with a value or a calculation involving int variable in a C box rather then a calculation box?
Or have I got that wrong and error is for a different reason.
This is the code I used in supplementary code window:
Int FCV_STD155_RPMF1[40]={807,844,880,917,954,990,1027,1060,1093,1126,1159,1192,1225,1258,1291,1324,1357,1390,1419,1442,1465,
1488,1511,1534,1557,1580,1603,1626,1649,1672,1696,1715,1734,1753,1772,1791,1810,1829,1848,1867,1886};
Re: Look-up-tables.
Posted: Fri Feb 19, 2010 4:28 pm
Figured out what was causing error.
too many initializers just simply mean you have more than declared number of items.
After count, I had 41 variables instead of declared 40.
Now compiles ok. Only problem is still going over memory allocation.
Re: Look-up-tables.
Posted: Fri Feb 19, 2010 5:14 pm
I have had an idea. I have run out of ram for variables location. What i can do is use flowcode to write 8bit numbers to flash, then retrieve stored numbers like an array. I believe u need to use flash.h is that correct?
