stack overflow
Posted: Sat Feb 20, 2010 1:41 pm
by Jan Lichtenbelt
I get a serious warming: stack usage exceeds 8. What to do? What can be the reason? And where do I have to check the programm?
Building CASM file
Serious Warning: Call stack usage exceeds:8!
Call Stack Usage Report
main and Task(s): hw used:8, exceeded by:0
interrupt: hw used:2, exceeded by:0
Memory Usage Report
RAM available:368 bytes, used:229 bytes (62.3%), free:139 bytes (37.7%),
Heap size:139 bytes, Heap max single alloc:95 bytes
ROM available:8192 words, used:6831 words (83.4%), free:1361 words (16.6%)
Re: stack overflow
Posted: Sun Feb 21, 2010 12:16 am
Basically each macro is treated as a subroutine = a stack. So if you have a Marco, calling a macro, calling a delay which I would assume a delay would be more than a stack? the stacks soon add up. Also an interrupt macro with a delay or calling another macro is a BIG no no. The solution would be to restructure your program or use a different microcontroller which has more stack levels.
Re: stack overflow
Posted: Sun Feb 21, 2010 11:26 am
by Jan Lichtenbelt
Do you know which parameter in the PIC specifications shows the amount of stack? Is that "architecture"?
I use now the PIC16F877A, but cannot find it anymore in the microchip list
http://www.microchip.com/ParamChartSear ... &pageId=74
Does that means this chip is not procuded anymore?
Re: stack overflow
Posted: Sun Feb 21, 2010 12:51 pm
First if you go into Matrix Multimedia/Flowcode V4/boostc/config directory
Then double click on the microcontroller you want to find out stack level for. Associate TDF extension with a text file editor (notepad will do) then read down the list and you will see Stack level. E.g for PIC16F877A shows:
Configure Core
    Type = PIC16F877A;
Configure ProgramMemory
    AddressRange = 0000h -> 1FFFh;
Configure StackHardware
    StackDepth = 8;
Configure EEPROM
    // EEPROM size in bytes
    // EEIF and EEIE bit must be correctly declared for interrupts
    Size = 256;
I am looking on the net for a product selection list that includes stack levels.
If I can find it, will post link.
Mean while something for you to try.
Take a look here:
http://www.microchip.com/productselecto ... ector.html
then with 8Bit selected move left slider on RAM (KB) to 0.5
With the results look at the stack level in files with TDF extension as mention above.
E.G for 18F2610
Type = PIC18F2610;
    AddressRange = 000000h -> 00FFFFh;
Configure AccessBank
    SplitAddr = 07Fh;
    StackDepth = 32;
You can the move other sliders E.g number of pins etc. To narrow down selection. Don't for get to have voltage slider on max 5.5.
Looking at the microchip range, you will need any microcontroller starting from 16F1000 and up! Which of course includes all 18F range,
as I believe they all have a stackdepth of at least 32
Hope this helps.
Re: stack overflow
Posted: Sun Feb 21, 2010 7:45 pm
by Jan Lichtenbelt
Thanks a lot. It seems easier to buy an other microchip compared to reprogramm my flowcode.
Re: stack overflow
Posted: Mon Feb 22, 2010 8:12 am
by Steve
There is a parameter for the BoostC compiler that will allow chip to use a software stack instead of a hardware stack. The information is in the "boostc.pdf" file.
Re: stack overflow
Posted: Mon Feb 22, 2010 9:27 am
Thanks Steve.
This issue is also covered here:
http://www.matrixmultimedia.com/mmforum ... 56&p=14010
Question. If you used a target chip with a higher hardware stack, does the software stack have the same higher limit as hardware stack?
Also is it not better to have a higher hardware stack if you want to increase sw stack, since it makes the running of the code more efficient?
Lastly do you know what the sw stack size could be increased to on the 16F877A for example?
Re: stack overflow
Posted: Mon Feb 22, 2010 10:22 am
by Steve
This is from the boostc datasheet:
-swcs s1 s2 s3
This command line option to the linker tells it to use a software call stack in
addition to the hardware call stack. This allows subroutine calls deeper than the
call hardware call stack of the PIC. A function call that is made on the software call
stack uses an extra byte of RAM to hold the return point number. This option must
be used when using Novo RTOS. Where possible the hardware stack is used for
efficiency. By specifying the depth of hardware stack to use for main (and Novo
tasks) s1, ISR (interrupt service routine) s2 and low priority ISR (PIC18 only) s3,
provides control over when the software call stack is used instead of the hardware
call stack. The software call stack is applied to functions higher up in the call tree,
so calls lower down the call tree still use the hardware call stack. If no hardware
stack depths are specified, then the software stack is only used in functions that
contain or call functions that contain a Novo RTOS Sys_Yield() function.
Example:
-swcs 6 2
Main routine will use hardware call stack up to a depth of 6 and then start using
software call stack. Interrupt routine will use hardware call stack up to a depth of 2
and start using software call stack. An ISR uses hardware call stack depth of 1 to
save the address of the point where the code was interrupted, so in this example it
only leaves a hardware call stack depth 1 for subsequent calls within the ISR.
You are right - a larger hardware stack is more efficient, but if there is room in the RAM for a chip then there should be no problem. It looks like the software stack depth is as high as the available RAM. It also seems to handle the size of the software stack behind the scenes - i.e. you only specify the size of the hardware stack to use.
Re: stack overflow
Posted: Mon Feb 22, 2010 10:59 am
Thanks for clearing that up Steve.
