graphical lcd programming with flowcode v3
Posted: Mon Feb 22, 2010 11:57 am
The program when executed gives some errors such as "missing paren, missing semicolon,etc.."
Pls tell the right program to interface monographic Lcd with IC18F4550
using flowcodev3
// Paste in the top of your 'GLCD - modified.C' file!
#define GLCD_DI PIN_C0 // Data or Instruction input
#define GLCD_RW PIN_C1 // Read/Write
#define GLCD_E PIN_C2 // Enable
#define GLCD_CS1 PIN_A3 // Chip Selection 1
#define GLCD_CS2 PIN_A4 // Chip Selection 2
#define GLCD_RST PIN_A5 // Reset
// Paste above "const int8 TEXT[51][5]"
//3x5 Font packed two per definition
//Original format from http://instruct1.cit.cornell.edu/course ... ideo32v2.c
// - Modified by Steven Cholewiak (http://www.semifluid.com)
// - 08/08/06 - Included punctuation characters
const int8 TEXT35[95][5]={
0b00000000, 0b00000000, 0b00000000, 0b00000000, 0b00000000, //SPACE
0b01000100, 0b01000100, 0b01000100, 0b00000000, 0b01000100, //!
0b10101010, 0b10101010, 0b00000000, 0b00000000, 0b00000000, //"
0b10101010, 0b11101110, 0b10101010, 0b11101110, 0b10101010, //#
0b01100110, 0b11001100, 0b11001100, 0b01100110, 0b11101110, //$
0b10101010, 0b00100010, 0b01000100, 0b10001000, 0b10101010, //%
0b01000100, 0b10101010, 0b01000100, 0b10101010, 0b01100110, //&
0b01000100, 0b01000100, 0b00000000, 0b00000000, 0b00000000, //'
0b01000100, 0b10001000, 0b10001000, 0b10001000, 0b01000100, //(
0b01000100, 0b00100010, 0b00100010, 0b00100010, 0b01000100, //)
0b00000000, 0b10101010, 0b01000100, 0b10101010, 0b00000000, //*
0b00000000, 0b01000100, 0b11101110, 0b01000100, 0b00000000, //+
0b00000000, 0b00000000, 0b00000000, 0b01000100, 0b10001000, //,
0b00000000, 0b00000000, 0b11101110, 0b00000000, 0b00000000, //-
0b00000000, 0b00000000, 0b00000000, 0b00000000, 0b01000100, //.
0b00100010, 0b00100010, 0b01000100, 0b10001000, 0b10001000, ///
0b11101110, 0b10101010, 0b10101010, 0b10101010, 0b11101110, //0
0b01000100, 0b11001100, 0b01000100, 0b01000100, 0b11101110, //1
0b11101110, 0b00100010, 0b11101110, 0b10001000, 0b11101110, //2
0b11101110, 0b00100010, 0b11101110, 0b00100010, 0b11101110, //3
0b10101010, 0b10101010, 0b11101110, 0b00100010, 0b00100010, //4
0b11101110, 0b10001000, 0b11101110, 0b00100010, 0b11101110, //5
0b11001100, 0b10001000, 0b11101110, 0b10101010, 0b11101110, //6
0b11101110, 0b00100010, 0b01000100, 0b10001000, 0b10001000, //7
0b11101110, 0b10101010, 0b11101110, 0b10101010, 0b11101110, //8
0b11101110, 0b10101010, 0b11101110, 0b00100010, 0b01100110, //9
0b00000000, 0b01000100, 0b00000000, 0b01000100, 0b00000000, //:
0b00000000, 0b01000100, 0b00000000, 0b01000100, 0b10001000, //;
0b00100010, 0b01000100, 0b10001000, 0b01000100, 0b00100010, //<
0b00000000, 0b11101110, 0b00000000, 0b11101110, 0b00000000, //=
0b10001000, 0b01000100, 0b00100010, 0b01000100, 0b10001000, //>
0b11001100, 0b00100010, 0b01100110, 0b00000000, 0b01000100, //?
0b01000100, 0b10101010, 0b11101110, 0b10001000, 0b01100110, //@
0b11101110, 0b10101010, 0b11101110, 0b10101010, 0b10101010, //A
0b11001100, 0b10101010, 0b11101110, 0b10101010, 0b11001100, //B
0b11101110, 0b10001000, 0b10001000, 0b10001000, 0b11101110, //C
0b11001100, 0b10101010, 0b10101010, 0b10101010, 0b11001100, //D
0b11101110, 0b10001000, 0b11101110, 0b10001000, 0b11101110, //E
0b11101110, 0b10001000, 0b11101110, 0b10001000, 0b10001000, //F
0b11101110, 0b10001000, 0b10001000, 0b10101010, 0b11101110, //G
0b10101010, 0b10101010, 0b11101110, 0b10101010, 0b10101010, //H
0b11101110, 0b01000100, 0b01000100, 0b01000100, 0b11101110, //I
0b00100010, 0b00100010, 0b00100010, 0b10101010, 0b11101110, //J
0b10001000, 0b10101010, 0b11001100, 0b11001100, 0b10101010, //K
0b10001000, 0b10001000, 0b10001000, 0b10001000, 0b11101110, //L
0b10101010, 0b11101110, 0b11101110, 0b10101010, 0b10101010, //M
0b00000000, 0b11001100, 0b10101010, 0b10101010, 0b10101010, //N
0b01000100, 0b10101010, 0b10101010, 0b10101010, 0b01000100, //O
0b11101110, 0b10101010, 0b11101110, 0b10001000, 0b10001000, //P
0b01000100, 0b10101010, 0b10101010, 0b11101110, 0b01100110, //Q
0b11101110, 0b10101010, 0b11001100, 0b11101110, 0b10101010, //R
0b11101110, 0b10001000, 0b11101110, 0b00100010, 0b11101110, //S
0b11101110, 0b01000100, 0b01000100, 0b01000100, 0b01000100, //T
0b10101010, 0b10101010, 0b10101010, 0b10101010, 0b11101110, //U
0b10101010, 0b10101010, 0b10101010, 0b10101010, 0b01000100, //V
0b10101010, 0b10101010, 0b11101110, 0b11101110, 0b10101010, //W
0b00000000, 0b10101010, 0b01000100, 0b01000100, 0b10101010, //X
0b10101010, 0b10101010, 0b01000100, 0b01000100, 0b01000100, //Y
0b11101110, 0b00100010, 0b01000100, 0b10001000, 0b11101110, //Z
0b11101110, 0b10001000, 0b10001000, 0b10001000, 0b11101110, //[
0b10001000, 0b10001000, 0b01000100, 0b00100010, 0b00100010, //\
0b11101110, 0b00100010, 0b00100010, 0b00100010, 0b11101110, //]
0b01000100, 0b10101010, 0b00000000, 0b00000000, 0b00000000, //^
0b00000000, 0b00000000, 0b00000000, 0b00000000, 0b11101110, //_
0b10001000, 0b01000100, 0b00000000, 0b00000000, 0b00000000, //`
0b00000000, 0b01000100, 0b10101010, 0b10101010, 0b01100110, //a
0b10001000, 0b11001100, 0b10101010, 0b10101010, 0b11001100, //b
0b00000000, 0b01100110, 0b10001000, 0b10001000, 0b01100110, //c
0b00100010, 0b01100110, 0b10101010, 0b10101010, 0b01100110, //d
0b00000000, 0b01000100, 0b10101010, 0b11001100, 0b01100110, //e
0b01100110, 0b01000100, 0b11101110, 0b01000100, 0b01000100, //f
0b00000000, 0b01000100, 0b10101010, 0b01100110, 0b11001100, //g
0b10001000, 0b11001100, 0b10101010, 0b10101010, 0b10101010, //h
0b01000100, 0b00000000, 0b01000100, 0b01000100, 0b01000100, //i
0b01000100, 0b00000000, 0b01000100, 0b01000100, 0b10001000, //j
0b10001000, 0b10001000, 0b10101010, 0b11001100, 0b10101010, //k
0b01000100, 0b01000100, 0b01000100, 0b01000100, 0b01000100, //l
0b00000000, 0b11101110, 0b11101110, 0b10101010, 0b10101010, //m
0b00000000, 0b11001100, 0b10101010, 0b10101010, 0b10101010, //n
0b00000000, 0b01000100, 0b10101010, 0b10101010, 0b01000100, //o
0b00000000, 0b11001100, 0b10101010, 0b11001100, 0b10001000, //p
0b00000000, 0b01100110, 0b10101010, 0b01100110, 0b00100010, //q
0b00000000, 0b10001000, 0b11101110, 0b10001000, 0b10001000, //r
0b00000000, 0b01100110, 0b11001100, 0b00100010, 0b11001100, //s
0b01000100, 0b11101110, 0b01000100, 0b01000100, 0b01000100, //t
0b00000000, 0b10101010, 0b10101010, 0b10101010, 0b01000100, //u
0b00000000, 0b10101010, 0b10101010, 0b01000100, 0b01000100, //v
0b00000000, 0b10101010, 0b10101010, 0b11101110, 0b10101010, //w
0b00000000, 0b10101010, 0b01000100, 0b01000100, 0b10101010, //x
0b00000000, 0b10101010, 0b10101010, 0b01100110, 0b11001100, //y
0b00000000, 0b11101110, 0b01100110, 0b11001100, 0b11101110, //z
0b00100010, 0b01000100, 0b11001100, 0b01000100, 0b00100010, //{
0b01000100, 0b01000100, 0b01000100, 0b01000100, 0b01000100, //|
0b10001000, 0b01000100, 0b01100110, 0b01000100, 0b10001000, //}
0b00000000, 0b11001100, 0b10101010, 0b00000000, 0b00000000 //~
// Paste above "glcd_fillScreen(int1 color)"
// Purpose: Write small text on a graphic LCD
// Inputs: (x,y) - The upper left coordinate of the first letter
// textptr - A pointer to an array of text to display
// color - ON or OFF
//char characterSet[] = " !#$%&'()*+,-./0123456789:;<=>?@ABCDEFGHIJKLMNOPQRSTUVWXYZ[\\]^_`abcdefghijklmnopqrstuvwxyz{|}~";
void glcd_text35(int8 x, int8 y, char* textptr, int1 color)
int i, j, k; // Loop counters
BYTE pixelData[5]; // Stores character data
for(i=0; textptr != '\0'; ++i, ++x) // Loop through the passed string
if((textptr >= ' ') && (textptr <= '~'))
memcpy(pixelData, TEXT35[textptr-' '], 5);
else
memcpy(pixelData, TEXT35[0], 5); // Default to space
if(x+3 >= GLCD_WIDTH) // Performs character wrapping
x = 0; // Set x at far left position
y += 5 + 1; // Set y at next position down
for(j=3; j>0; j--, x++) // Loop through character byte data
for(k=0; k<5; k++) // Loop through the vertical pixels
if(bit_test(pixelData[k], j)) // Check if the pixel should be set
glcd_pixel(x, y+k, color); // Draws the pixel
#include <18F2550.h>
#device ADC=8
#fuses HSPLL,NOWDT,NOPROTECT,NOLVP,NODEBUG,USBDIV,PLL5,CPUDIV1,VREGEN
#use delay(clock=48000000)
#build(reset=0x1, interrupt=0x8) // Necessary for Bootloader
#ORG 0x0F00,0x0FFF {} // Necessary for Bootloader
#use rs232(stream=PC, baud=115200, xmit=PIN_C6, rcv=PIN_C7, ERRORS)
#include <GLCD - modified.c> // Includes 3x5 font
#INT_RDA
void serial_isr() // Serial Interrupt
if (fgetc(PC) == 0x12 & fgetc(PC) == 0x34 & fgetc(PC) == 0x56 & fgetc(PC) == 0x78 & fgetc(PC) == 0x90) #asm reset #endasm
void main() {
SETUP_ADC_PORTS(NO_ANALOGS); // Disable ADC
SETUP_ADC(ADC_OFF); // Disable ADC
SETUP_TIMER_0(RTCC_INTERNAL|RTCC_DIV_1); // Use the int. osc. for Timer 0
SETUP_TIMER_1(T1_DISABLED); // Disable Timer 1
SETUP_TIMER_2(T2_DISABLED, 127, 1); // Disable Timer 2
SETUP_TIMER_3(T3_DISABLED); // Disable Timer 3
SETUP_CCP1(CCP_OFF); // Disable CCP1
SETUP_CCP2(CCP_OFF); // Disable CCP2
enable_interrupts(INT_RDA);
enable_interrupts(GLOBAL);
glcd_init(ON); // Must initialize the LCD
glcd_text35(0, 0, characterSet, ON); // Write character set to LCD
while (TRUE) {}
I'''
using flowcodev3
else
#device ADC=8
#INT_RDA
void main() {
while (TRUE) {}
I'''
