Using Microchip's Usb HID firmware for ECIO 28P
Posted: Thu Apr 08, 2010 1:50 pm
Hi. I'm using a ECIO28P for my project to control a DC motor using a user friendly program (using Microsoft visual express c#) via USB. I'm currently trying to get the module to be recognised as a HID device using the MCHPFSUSB firmware from Microchip with no luck. I've edited the code as if it were designed for the PIC18f2455. The program builds succesfully in MPLAB but not getting a activity when i load the program onto the ECIO module.
Would there be specific changes to account for using the p18f2455 on the ECIO28p? or would the program's configuration be exactly as if i was using a standalone pic18f2455?
The more obvious question is whether its possible to do what i'm attempting to do? The reason i ask is because i noticed that the USB pins are not found on the module since the USB socket is already integrated.
Also, i havent configured the config bits in case it affected the bootloader. I was thinking of using the settings the firmware uses for the P18f4550 shown below:
#if defined(PICDEM_FS_USB) // Configuration bits for PICDEM FS USB Demo Board (based on PIC18F4550)
#pragma config PLLDIV = 5 // (20 MHz crystal on PICDEM FS USB board)
#pragma config CPUDIV = OSC1_PLL2
#pragma config USBDIV = 2 // Clock source from 96MHz PLL/2
#pragma config FOSC = HSPLL_HS
#pragma config FCMEN = OFF
#pragma config IESO = OFF
#pragma config PWRT = OFF
#pragma config BOR = ON
#pragma config BORV = 3
#pragma config VREGEN = ON //USB Voltage Regulator
#pragma config WDT = OFF
#pragma config WDTPS = 32768
#pragma config MCLRE = ON
#pragma config LPT1OSC = OFF
#pragma config PBADEN = OFF
// #pragma config CCP2MX = ON
#pragma config STVREN = ON
#pragma config LVP = OFF
// #pragma config ICPRT = OFF // Dedicated In-Circuit Debug/Programming
#pragma config XINST = OFF // Extended Instruction Set
#pragma config CP0 = OFF
#pragma config CP1 = OFF
// #pragma config CP2 = OFF
// #pragma config CP3 = OFF
#pragma config CPB = OFF
// #pragma config CPD = OFF
#pragma config WRT0 = OFF
#pragma config WRT1 = OFF
// #pragma config WRT2 = OFF
// #pragma config WRT3 = OFF
#pragma config WRTB = OFF // Boot Block Write Protection
#pragma config WRTC = OFF
// #pragma config WRTD = OFF
#pragma config EBTR0 = OFF
#pragma config EBTR1 = OFF
// #pragma config EBTR2 = OFF
// #pragma config EBTR3 = OFF
#pragma config EBTRB = OFF
I'm using MPLAB c18 compiler to program the p18f2455.
Mike
Mike
