LED7SEG4 Module
Posted: Wed May 19, 2010 9:05 am
by Frank123
I use the 4 x 7 segments and I have some problems.
- I would have a module clock 88:88.
- My diagramm is with PNP must therefore low state to select digit and low state to turn on each segment. I think in the next version you should add this feature. like one LED model.
- Possibility to have 2, 3, 4, 5, 6 ... digits
Re: LED7SEG4 Module
Posted: Wed May 19, 2010 9:35 am
Hello Frank,
The quad 7 segment is a bit of a legacy component. The single 7-segment component can be stacked togther to create a display with as many digits as you like. The segment connections can all be commoned together and the anode or cathode can be manipulated individually for each display. You could even add the : character by adding a relevant background image to the panel.
Re: LED7SEG4 Module
Posted: Wed May 19, 2010 11:56 am
by Frank123
Hello Ben,
But i can't put an inverter lijke PNP transistor, then i can't turn on one digit with low state
and turn on one segment with low state too.
Re: LED7SEG4 Module
Posted: Thu May 20, 2010 8:40 am
Hello Frank,
You would need a PNP transistor for each of the common pins. This should allow the device to work with both segment and common pins active low.
Re: LED7SEG4 Module
Posted: Thu May 20, 2010 9:30 am
by Frank123
But is it possible with flowcode to add an inverter ?
