DTMF
Posted: Fri Jun 11, 2010 7:21 am
How can I generate a DTMF signal with flowcode.
I would like to generate the following signals
The lower group has 4 frequencies; 697 , 770 , 852 and 941 Hz
The higher group has 4 frequenties; 1.209, 1.336, 1.477 and 1.633 Hz
These DTMF tones are similar as from a keypad from a telephone.
I did read that PICBASIC has a function for this, does flowcode this option or is there an example of this.
Maybe something like DTMF (port, bit, timeon, timeoff, Low hz, high hz)
DTMF (B,1,40,40,697,1.209)
Key DTMF Low,High freq
'1 [ 697, 1209 ]. . . . '6 [ 770, 1477 ]. . . . '* [ 941, 1209 ]
'2 [ 697, 1336 ]. . . . 'B [ 770, 1633 ]. . . . '0 [ 941, 1336 ]
'3 [ 697, 1477 ]. . . . '7 [ 852, 1209 ]. . . . '# [ 941, 1477 ]
'A [ 697, 1633 ]. . . . '8 [ 852, 1336 ]. . . . 'D [ 941, 1633 ]
'4 [ 770, 1209 ]. . . . '9 [ 852, 1477 ]
'5 [ 770, 1336 ]. . . . 'C [ 852, 1633 ]
