Using EB006 with 16F883
Posted: Wed Jul 14, 2010 9:10 am
This target device can fail to program. This is not a fault with EB006 or PPP.
If you use a 12V supply, although it states on DS41287 document from microchip VPP is 12V max, this is clearly not the case with 16F883, but is fine for a majority of other devices.
PICkit 2 programmers are also affected, since the one I have only produces 12V on VPP line.
Using this programmer in HVP for ICSP, programming only randomly worked, and kept getting device not detected. Using a different ICSP programmer, device was programmed sucsefully 100% of the time. I don’t know what other devices are affected, so if programming fails, please bear this in mind.
Conclusion use recommended PSU which produces a voltage higher than 12V.
I was using a stabilized 12V supply, which is fine for a majority of devices, just not 16F883!
I believe this topic has been covered elsewhere, but I’d thought I would share my experience.
Thank you.
Thank you.
