E-Blocks (some) testfiles won't work
Posted: Mon Aug 30, 2010 12:32 pm
by yfands
Goodday,
I purchased Flowcode in march together with the e-blocks switch, led and lcd.
The cd contains flowcode version, 4.2.3.58 had to upgrade to 4.3.7.63 because some
icons were misplaced. In my opinion all components are working, I can place them and
edit there connections.
Last week I purchased the e-blocks eb0008, eb0011, eb0013 and eb0022.
none of the testfiles from the download work.
All I get is an error:
"Flowcode could not load one of the components in the file because it is not registered on this machine. Install the necessary components before this file"
So I went to the forum for some answers:
What I already did (without result)
- Change the language in the global settings. (it was dutch, tried english also).
- Reregister the components with the supplied .bat file
- Reinstalled the new downloaded flowcode.exe (after deinstalling flowcode)
- Rerereinstalled the downloaded flowcode.exe after running the unregister components.bat and deinstalling flowcode and edit the regedit file removing let over
entries regarding flowcode ie. some preferences were still there !
- repeated the above step and installed flowcode from the cd version 4.2.3.58, still no luck getting the same error and a new one,
Error: Access violation at 0x0046CB16 (tried to read from 0x00000020), program terminated.
an update from 4.2. -> 4.3 helps, no error violation anymore, but the component issue stays.
any ideas ?
the only thing i can comeup with is the files are written for flowcode V3..
The examples from the website for instance 2. Counting using loops.FCF works like a charme with
the 7 segment component, but the testfile for the 7 segments board eb0008 wont load without the error
Flowcode could not load one of the components etc....
my OS is
win7 ultimate dutch (32 bits)
(o, btw the registry entry language is blanc and profile is flowcode 4)
maybe that somebody can reply if the testfiles do work and name the
configuration used (version flowcode and OS)
Regards Frank
Re: E-Blocks (some) testfiles won't work
Posted: Tue Aug 31, 2010 9:55 am
Hi Frank,
I've answered your question elsewhere. Please do not double post on the forums.
