V4 compiling error
nmindana
Has thanked: 52 times
Been thanked: 5 times
V4 compiling error
Post by nmindana »
Dear All,
Whilst trying to programme and compile the following attached file, I am stuck with a compiler error, works fine on Simulation :!:
Please advice.
File name: D:\Documents and Settings\MURTHY.HOME\Desktop\data logging can manipulate.c
Generated by: Flowcode v4.3.7.63
Date: Thursday, January 13, 2011 21:47:37
Licence: Professional
Registered to: narayanaindana
Launching the compiler...
C:\Program Files\Matrix Multimedia\Flowcode V4\BoostC\boostc.pic16.flowcode.exe -v -t PIC16F88 "data logging can manipulate.c"
BoostC Optimizing C Compiler Version 6.95 (for PIC16 architecture)
http://www.sourceboost.com
Copyright(C) 2004-2009 Pavel Baranov
Copyright(C) 2004-2009 David Hobday
Licensed to FlowCode User under Single user Pro License for 1 node(s)
Limitations: PIC12,PIC16 max code size:Unlimited, max RAM banks:Unlimited
Starting preprocessor: C:\PROGRA~1\MATRIX~1\FLOWCO~1\BoostC\pp.exe "D:\Documents and Settings\MURTHY.HOME\Desktop\data logging can manipulate.c" -i C:\PROGRA~1\MATRIX~1\FLOWCO~1\BoostC\include -d _PIC16F88 -la -c2 -o "D:\Documents and Settings\MURTHY.HOME\Desktop\data logging can manipulate.pp" -v -d _BOOSTC -d _PIC16
D:\Documents and Settings\MURTHY.HOME\Desktop\data logging can manipulate.c(1714): error: missing right paren
D:\Documents and Settings\MURTHY.HOME\Desktop\data logging can manipulate.c(1714): error: error in 'if' expression
D:\Documents and Settings\MURTHY.HOME\Desktop\data logging can manipulate.c(1714): error: missing semicolon
D:\Documents and Settings\MURTHY.HOME\Desktop\data logging can manipulate.c(1258): error: failure
failure
Return code = 1
FINISHED
data logging can manipulate.fcf
(34.39 KiB) Downloaded 408 times
Re: V4 compiling error
Hi nmindana,
If you look in main of your flowchart and scroll down to decision: EEAddress < =90
There is a space between < and =. This is reason for failure. after removing space (shoud be <= ), should compile OK
If you look at:
http://www.matrixmultimedia.com/mmforum ... =26&t=6936
There is some information there on how to find the part of flowchart causing the error when line numbers are given.
nmindana
Post by nmindana »
What can I say, you are Brilliant 8)
Long live medelec35.
Can't thank you enough.
Indana
Thank you for the kind words & feedback.
Just glad your flowchart is compiling for you now.
nmindana
Post by nmindana »
I am trying to a print "%" (percentage) symbol on the LCD without much success, can any help.
Indana
I have tried using standard LCD eblock EB-005, and % displays OK. I am assuming you are using the 'Print String' function?
If you have a different LCD, then can you place a link for LCD or datasheet. in the unlikely event your LCD does not have % stored within its memory, then a custom character can be made.
nmindana
Post by nmindana »
Thanks once again :D
Your welcome,
Once again lol.
nmindana
EEPROM problem
Post by nmindana »
The following programme is meant to time events and store it in EEPROM, upon press "read button" is meant to display the result as percentages.
It works fine on simulation, but returns "255" on hardware for a value of "0", can't understand why, please help !
I am using 16F88 chip, INTRC 8Mghz /LCD display / EB006 (programmer).
(37.1 KiB) Downloaded 407 times
When using pic maths, you will need to multiply first to improve accuracy (so long as result does not exceed 32767). If not the following will happen:
E.g If Trigger=15 & Total=47.
result from simulator = (15/47)*100
= 0.31*100
= 31
Result on hardware
= (15/47)*100
=0*100
=0
as you can see the simulator rounds result of 1st calculation to 2 or 3 decimal places.
Microcontroller does not!
Try:
(Trigger*100)/Total
nmindana
Post by nmindana »
Hi medelac,
Tried your suggestion, still displays a value of 255, not sure if my erase macro is working well on PIC, works ok on simulation.
Please advice ? :cry:
nmindana
Post by nmindana »
Hi when an event is not trigger it displays a value of 255 on lcd, it should be "0" ? works on simulation but something wrong with pic ?
nmindana
Post by nmindana »
Hi, I am struggling to get EEprom work on 16F88, the attached programme works OK on simulation, but not on the hardware.
The LCD reads "255", instead of "0".
Viewing complied C, reveals the following error. Flowcode does not support eeprom for this device ? see below !
Please advice :cry:
//EEPROM(0): //Macro implementations
char FCD_EEPROM0_EEPROMRead(short addr)
char data = 0;
#ifdef _BOOSTC
#ifdef MX_EE
#ifndef MX_EEADR
#ifdef EEADR
#define MX_EEADR eeadr
#endif
#ifdef EEADRL
#define MX_EEADR eeadrl
#endif
#endif
#ifndef MX_EEDATA
#ifdef EEDATA
#define MX_EEDATA eedata
#endif
#ifdef EEDATAL
#define MX_EEDATA eedatal
#endif
#ifdef EEDATL
#define MX_EEDATA eedatl
#endif
#endif
#ifndef MX_EEADR //Catch Error
#ifdef _BOOSTC
#pragma error "EEPROM error - MX_EEADR not set"
#endif
#ifdef HI_TECH_C
#error EEPROM error - MX_EEADR not set
#endif
#endif
#ifndef MX_EEDATA
#ifdef _BOOSTC
#pragma error "EEPROM error - MX_EEDATA not set"
#endif
#ifdef HI_TECH_C
#error EEPROM error - MX_EEDATA not set
#endif
#endif
MX_EEADR = addr & 0xff;
#if (MX_EE_SIZE > 256)
eeadrh = (addr & 0xff00) >> 8;
#endif
#ifdef MX_EE_TYPE2
clear_bit(eecon1, EEPGD);
#endif
#ifdef MX_EE_TYPE3
clear_bit(eecon1, CFGS);
#endif
set_bit(eecon1, RD);
data = MX_EEDATA;
#else
#ifdef MX_EE_TYPE67X
#ifdef _BOOSTC
#pragma error "FlowCode does not support EEPROM for this device"
#endif
#ifdef HI_TECH_C
#error FlowCode does not support EEPROM for this device
#endif
#else
#ifdef MX_EE_TYPE62X
#ifdef _BOOSTC
#endif
#ifdef HI_TECH_C
#endif
#else
#ifdef _BOOSTC
#pragma error "Chip does not have EEPROM memory"
#endif
#ifdef HI_TECH_C
#error Chip does not have EEPROM memory
#endif
#endif
#endif
#endif
#endif
#ifdef HI_TECH_C
data = eeprom_read(addr);
#endif
return (data);
(37.19 KiB) Downloaded 375 times
I believe all the code:
		char data = 0;
		#ifdef _BOOSTC
			#ifdef MX_EE
				#ifndef MX_EEADR
					#ifdef EEADR
					#endif
					#ifdef EEADRL
					#endif
				#endif
				#ifndef MX_EEDATA
					#ifdef EEDATA
					#endif
					#ifdef EEDATAL
					#endif
					#ifdef EEDATL
					#endif
				#endif
					#ifdef _BOOSTC
					#endif
					#ifdef HI_TECH_C
					#endif
				#endif
				#ifndef MX_EEDATA
					#ifdef _BOOSTC
					#endif
					#ifdef HI_TECH_C
					#endif
				#endif
				#endif
				#ifdef MX_EE_TYPE2
				#endif
				#ifdef MX_EE_TYPE3
				#endif
				data = MX_EEDATA;
			#else
					#ifdef _BOOSTC
					#endif
					#ifdef HI_TECH_C
					#endif
				#else
						#ifdef _BOOSTC
						#endif
						#ifdef HI_TECH_C
						#endif
					#else
						#ifdef _BOOSTC
						#endif
						#ifdef HI_TECH_C
						#endif
					#endif
				#endif
			#endif
		#endif
		#ifdef HI_TECH_C
		#endif
		return (data);
applies to every flowchart that is compiled, and are just conditions for the components you use (only components that are not available to all target devices) so the compiler knows what to compile. If you use a PWM component, it will show similar FlowCode does not support warnings.
You can ignore these warnings, since your target has EEPROM, they do not apply to you.
Could it be that the EEPROM is being erased when you re-program your device? The default state for EEPROM is to read back 255. If you do not want the EEPROM to be erased during programming then there is an option to turn off this functionality by clicking Chip -> Configure -> Options.
nmindana
Post by nmindana »
Hi thanks for the reply.
The chip is initially reset before it is issued to the customer by pressing the Erase button.
This fills up the first half of eeprom data with byte "55" and the rest half to "0"
What the programme is meant to do is to record events to EEPROM on pressing trigger button in the first half, and once the read button is pressed data is read and displayed on the LCD. What is happening now is that if no events have happened it returns "255" instead of "0", although eeprom is initially reset as above. If there are triggered events it displays the correct value.
(37.67 KiB) Downloaded 289 times
First try this:
In your initialize macro, set variables to 0 that may not be read if conditions are not met e.g:
RESULT1 = 0
RESULT2 = 0
RESULT = 0
That may solve your problem?
I believe you are just reading initialised variables.
If this is not the case
It may be an idea to determine if problem is with Flowchart not reading or writing correctly to EEPROM, or just a problem with your calulations.
One way to check is:
Run hardware and press A1 button to erase chip.
Run PPPv3 (can be found in C:\Program Files\Matrix Multimedia\Flowcode V4\Tools\PPP)
Click 'View' menu then 'View PICmicro' ppp will then read chip.
You can then see all the contents of EEPROM, so you can check if all EEPROM location are set at correct values
For instance, I used a 18F4455. pressed switch A1. used ppp to read data. Got this:
EEPROM Contents.jpg (90.01 KiB) Viewed 15712 times
As you can see, Quiet a few EEPROM locations are filled with 0x37 = 55 decimal. Also what you can't see are quiet a few locations are filled with 0's.
nmindana
Post by nmindana »
Thanks medelec35,
Very clever idea, which I have not thought about, will have a look and let you know, how I got on.
Indana
nmindana
Post by nmindana »
Dear All,
Thank you for all your help. Flowcode is a brilliant piece of software.
I have sorted out my problem, problem with maths, just realised 0/0 is undefined value, which the PIC reads as 255.
Special thanks to medelec35 who ans every question posted, which is very helpful for novices like me. Phew it's been a steep
learning curve. Thanks to all the clever people behind flowcode.
Indana
Thats great! Glad you a managed to solve this one, well done.
Your welcome and thanks. I don't always get it right, but glad when I do, especially I helped some one resolve their issue. :-)
That is such an intresting and useful fact (I did not know that!), I Have used it here:
http://www.matrixmultimedia.com/mmforum ... 368#p16368
See, you will be helping others as well :-)
I'm sure loads of users (my self included) agree with that!
