ST7565 graphical LCD Serial
Posted: Thu Jan 20, 2011 12:00 am
by cruzxia
I want to use a 128 x 64 gLCD with a ST7565 controller. From the data sheet it can be connected in parallel or serial data formats. I want to connect it with a serial interface to reduce the number of connections.
Can I use the Flowcode V4 gLCD (in the output menu) as it is configured for serial data.
Or
Will I have to modify and create custom code for the ST7565 to use serial data.
Andrew
Re: ST7565 graphical LCD Serial
Posted: Thu Jan 20, 2011 2:06 pm
Hello Andrew,
There is a custom component available from here to drive the ST7565 LCD using Flowcode.
http://www.matrixmultimedia.com/Flowcode_Components.php
I think it uses the parrallel method of writing to the display but you should be able to modify the component code so that it uses the alternative serial format. Let me know how you get on.
Posted: Mon Feb 07, 2011 11:42 am
by cruzxia
I finally received my serial displays. I decided to bit bang the data, as it is only data out (you can’t read from the display in serial mode).
I can’t seem to get the display to initialise. The SPI data is read from the serial data pin in the rising edge of the serial clock. D7 through D0 (MSB first)
I have been using a Custom C code component in Flowcode 4. Here is the bit bang section, can you see any problems?
To send a command I use:
gLCD_SendByte(MX_LCD_CMD,0xA4);	// where 0xA4 is the command data
To send data I use:
 gLCD_SendByte(MX_LCD_PARAM,DATA);     // Where Pram is 1
This is the code to send a byte.
void gLCD_SendByte (char Command, char Lcdout)
/*Macro_gLCD_SendByte_Start*/
    char i;
    clear_bit(MX_CONTROL_PORT, MX_CS1);              //MX_GLCD_CS1 0 start of sequence
    clear_bit(MX_CONTROL_PORT, MX_SCLK);            //Clock 0
    if (Command == MX_LCD_CMD)
        clear_bit(MX_CONTROL_PORT, MX_DAT_INST);       //0 = MX_LCD_CMD
    else
        set_bit(MX_CONTROL_PORT, MX_DAT_INST);         //1 = MX_GLCD_PARAMeter
    set_bit(MX_CONTROL_PORT, MX_SCLK);
    for (i=0;i<8;i++)
        if (Lcdout & 0x80)
            set_bit(MX_CONTROL_PORT, MX_SDATA);     //Output MSB
        else
            clear_bit(MX_CONTROL_PORT, MX_SDATA);
        set_bit(MX_CONTROL_PORT, MX_SCLK);          //Clock 1
        Lcdout = Lcdout << 1;                             //Shift Data to left
    set_bit(MX_CONTROL_PORT, MX_CS1);                //MX_GLCD_CS1 to 1 at end of sequence
I will setup the print string code once I know that the comunication is working.
Andrew
Data sheet info is as follows:
Posted: Mon Feb 07, 2011 12:11 pm
by cruzxia
Good news
I found the problem it was a hardware issue, one wire had come off the connector. So The SPI code works I posted previously works.
However!
When it prints a string it is just a row of solid pixels. I used your ST7565 code example for the parallel version, but it needs to read the display in most subroutines. Any ideas how to overcome this problem?
Andrew
Posted: Tue Feb 08, 2011 12:37 pm
Hello Andrew,
Great glad you got it working. When printing a string are you using the ASCII look up table method? Eg there is a set of arrays that contain the data for each ASCII charater. The print routine should scan the ascii data and set a pixel if the appropriate ascii data bit is set? Are other functions such as draw line etc working as expected?
Posted: Wed Feb 09, 2011 7:47 am
by cruzxia
Ben
I decided to test the Parallel interface first, to check that it worked as expected. There are two versions ST7565R chip, (6800 series and 8080 series) typically I have the other version.
The changes for the 8080 version were to do with communication. As follows:
Write a Command AO = L , RD = H , WR = L , Move data to port , CS1 = L , delay , CS1 = H
Write Data AO = H , RD = H , WR = L , Move data to port , CS1 = L , delay , CS1 = H
Read DisplayAO = H , RD = L , WR = H , CS1 = L , delay, Read port , CS1 = H
The problem I have is that it wont display any characters correctly and seems to be double spaced.
I think that it has something to do with Reading the display, or the page function. When I draw a text box it seems to not recognise the vertical line numbers, It jumps up 8 pixels at a time.
Eg doing an outline the top is either not there or about 8 pixels thick. photo below
In the photo, Inside the box, the text is “Hello” (centre) and I drew two lines one across the bottom and one vertically in front of the text.
Note: I disabled the Read display function, and the horizontal line draws correctly, but vertical line and text are not displayed.
I read the data sheet, and it said that when sending display data, the specified column address is incremented with each display data read/write command.
I have attached the custom C code that I have revised the comunication from the 6800 to the 8080 version of the ST7565R, can you please have a quick look if I missed something.
Andrew
Posted: Wed Feb 09, 2011 3:27 pm
Hello Andrew,
Looks like your nearly there. I had a quick look at your C file but without hardware to test on and digging into the datasheet its hard to tell if its ok. My guess is that the coordinate system you are using is not quite right and this is causing the display to be corrupted. I know that on these black and white devices you write to 8 pixels in one go rather then a pixel at a time as with the colour displays. Maybe this could be the issue? Let me know how your getting on and ill have a bit of a better look when I get some time.
Posted: Thu Feb 10, 2011 6:07 am
by cruzxia
I am having trouble finding the problem :cry: ; I have narrowed it down to two possible causes.
1. When reading/writhing to the display the line is automatically incremented in the display.
This shows up as spread out text on the display
2. The page system of the display requires setting the page and column via commands.
So the x y positions are incorrect if you don’t set the page.
The c coding that I have used was the file for the ST7565 display so if it was originally tested with a display it should be correct.
To test the display I created a Print Bytes routine, input the ASCII 5 character values, and it prints on the screen In 8x5. So the screen works. The display automatically moves to the next line after each character value is written.
void LCD_Print_Bytes(char byt1, char byt2, char byt3, char byt4, char byt5, char x, char y)
/*Macro_LCD_Print_Bytes_Start*/
		MX_GotoXY(x, y);
		set_bit(MX_CONTROL_PORT, MX_DAT_AO);			//Configure = data
		set_bit(MX_CONTROL_PORT, MX_READ_WRITE_RD);		//Configure to write data !
		set_bit(MX_CONTROL_PORT, MX_READ_WRITE_WR);			//Write cammand
	MX_DATA_TRIS = 0x00;						//Configure data port as output
	MX_DATA_PORT = byt1;							//Load data to port
	MX_LCD_Enable();
	MX_DATA_PORT = byt2;							//Load data to port
	MX_LCD_Enable();
	MX_DATA_PORT = byt3;							//Load data to port
	MX_LCD_Enable();
	MX_DATA_PORT = byt4;							//Load data to port
	MX_LCD_Enable();
	MX_DATA_PORT = byt5;							//Load data to port
	MX_LCD_Enable();
	MX_DATA_PORT = 0x00;
//MX_WriteData(byt);
/*Macro_LCD_Print_Bytes_End*/
The data sheet is here.
http://www.sitronix.com.tw/sitronix/SAS ... 980914.pdf
See page 26 and 27
Andrew
Posted: Thu Feb 10, 2011 7:18 am
by cruzxia
Ben
I just did an X Y position test using 8x5 pixel blocks.
If X and Y are 0,0 it prints in the corner as expected
If X and Y are 0,8 it prints 8 pixels up as expected
If X and Y are 0,7 it prints back in the corner. Not expected. So there seems to be some issue with the pages and vertical coordinates.
Do you have any ideas on the XY problem? If I can fix this then the rest may fall in to place.
Andrew
