I managed to write a small program to count up or down depending on the push button that is pressed. The delay for de-bouncing, is this more for when running the simulation than actual practice? I already have a small delay in the program so that the count does not go crazy when clicking the button with the mouse.
Bob
Flowcode Demo Switch debounce
Re: Flowcode Demo Switch debounce
When I use a delay for switch debounce, I place delay so that there is only a delay after switch press has been detected.
That way, rest of program is not slowed down if no switches are pressed.
Change the delay to suit.
I believe it would be best to keep a delay of some value in practice, since as switches get older, bounce gets worse.
- Switch_Debounce FCV4.fcf
- (7 KiB) Downloaded 772 times
