Timer0
Posted: Fri Feb 11, 2011 9:29 am
by wayne millard
Hi Team,
How do i write to timer0 on a 18F4520
Wayne
Re: Timer0
Posted: Fri Feb 11, 2011 10:07 am
Hello Wayne,
In normal 8-bit mode you write to the timer count register by doing the following in a C code block.
tmr0l = 0x00;
Or if you had a Flowcode variable you wanted to pass then you could do it like this
tmr0l = FCV_VARNAME;
where varname is the name of your Flowcode variable.
