pic16f1827 Send to ic Error
Posted: Wed Feb 23, 2011 10:41 am
Hi I try to program a PIC16F1827 but it does not work
I use Flowcode 4.3.7.63 / PPPv3 ver 3.9.12.26 / and EB-006-00-6 board
I start Flowcode and select PIC16F1827 and write a simpel led flash program to port B0.
In IC - Konfiguration - switch to Expert config screen When I compile the IC I get the following message and nothing happened at IC?
(( there are no problems when I send the program to a pic16f88 ))
Hope someone can help Regards Frank
File name: C:\Documents and Settings\frank\My Documents\My Dropbox\flowcode\Programmer\servostyrring\1servo\testmid.c
Generated by: Flowcode v4.3.7.63
Date: Wednesday, February 23, 2011 12:16:00
Licence: Professional
Registered to: Biologisk Institut
Launching the compiler...
C:\Program Files\Matrix Multimedia\Flowcode V4\BoostC\boostc.pic16.flowcode.exe -v -t PIC16F1827 "testmid.c"
BoostC Optimizing C Compiler Version 6.95 (for PIC16 architecture)
http://www.sourceboost.com
Copyright(C) 2004-2009 Pavel Baranov
Copyright(C) 2004-2009 David Hobday
Licensed to FlowCode User under Single user Pro License for 1 node(s)
Limitations: PIC12,PIC16 max code size:Unlimited, max RAM banks:Unlimited
testmid.c
Starting preprocessor: "C:\PROGRA~1\Matrix Multimedia\Flowcode V4\BoostC\pp.exe" "C:\Documents and Settings\frank\My Documents\My Dropbox\flowcode\Programmer\servostyrring\1servo\testmid.c" -i "C:\PROGRA~1\Matrix Multimedia\Flowcode V4\BoostC\include" -d _PIC16F1827 -la -c2 -o "C:\Documents and Settings\frank\My Documents\My Dropbox\flowcode\Programmer\servostyrring\1servo\testmid.pp" -v -d _BOOSTC -d _PIC16
C:\Documents and Settings\frank\My Documents\My Dropbox\flowcode\Programmer\servostyrring\1servo\testmid.c(85:2): error: unknown identifier 'ansela'
C:\Documents and Settings\frank\My Documents\My Dropbox\flowcode\Programmer\servostyrring\1servo\testmid.c(85:2): error: invalid operand 'ansela'
C:\Documents and Settings\frank\My Documents\My Dropbox\flowcode\Programmer\servostyrring\1servo\testmid.c(85:9): error: failed to generate expression
C:\Documents and Settings\frank\My Documents\My Dropbox\flowcode\Programmer\servostyrring\1servo\testmid.c(86:1): error: unknown identifier 'anselb'
C:\Documents and Settings\frank\My Documents\My Dropbox\flowcode\Programmer\servostyrring\1servo\testmid.c(86:1): error: invalid operand 'anselb'
C:\Documents and Settings\frank\My Documents\My Dropbox\flowcode\Programmer\servostyrring\1servo\testmid.c(86:8): error: failed to generate expression
C:\Documents and Settings\frank\My Documents\My Dropbox\flowcode\Programmer\servostyrring\1servo\testmid.c(90:2): error: unknown identifier 'option_reg'
C:\Documents and Settings\frank\My Documents\My Dropbox\flowcode\Programmer\servostyrring\1servo\testmid.c(90:2): error: invalid operand 'option_reg'
C:\Documents and Settings\frank\My Documents\My Dropbox\flowcode\Programmer\servostyrring\1servo\testmid.c(90:13): error: failed to generate expression
C:\Documents and Settings\frank\My Documents\My Dropbox\flowcode\Programmer\servostyrring\1servo\testmid.c(99:2): error: unknown identifier 'trisb'
C:\Documents and Settings\frank\My Documents\My Dropbox\flowcode\Programmer\servostyrring\1servo\testmid.c(99:2): error: invalid operand 'trisb'
C:\Documents and Settings\frank\My Documents\My Dropbox\flowcode\Programmer\servostyrring\1servo\testmid.c(99:8): error: failed to generate expression
C:\Documents and Settings\frank\My Documents\My Dropbox\flowcode\Programmer\servostyrring\1servo\testmid.c(101:2): error: unknown identifier 'portb'
C:\Documents and Settings\frank\My Documents\My Dropbox\flowcode\Programmer\servostyrring\1servo\testmid.c(101:2): error: invalid operand 'portb'
C:\Documents and Settings\frank\My Documents\My Dropbox\flowcode\Programmer\servostyrring\1servo\testmid.c(101:8): error: failed to generate expression
C:\Documents and Settings\frank\My Documents\My Dropbox\flowcode\Programmer\servostyrring\1servo\testmid.c(101:2): error: error in the body of 'if' expression
C:\Documents and Settings\frank\My Documents\My Dropbox\flowcode\Programmer\servostyrring\1servo\testmid.c(113:2): error: unknown identifier 'trisb'
C:\Documents and Settings\frank\My Documents\My Dropbox\flowcode\Programmer\servostyrring\1servo\testmid.c(113:2): error: invalid operand 'trisb'
C:\Documents and Settings\frank\My Documents\My Dropbox\flowcode\Programmer\servostyrring\1servo\testmid.c(113:8): error: failed to generate expression
C:\Documents and Settings\frank\My Documents\My Dropbox\flowcode\Programmer\servostyrring\1servo\testmid.c(115:2): error: unknown identifier 'portb'
C:\Documents and Settings\frank\My Documents\My Dropbox\flowcode\Programmer\servostyrring\1servo\testmid.c(115:2): error: invalid operand 'portb'
C:\Documents and Settings\frank\My Documents\My Dropbox\flowcode\Programmer\servostyrring\1servo\testmid.c(115:8): error: failed to generate expression
C:\Documents and Settings\frank\My Documents\My Dropbox\flowcode\Programmer\servostyrring\1servo\testmid.c(115:2): error: error in the body of 'if' expression
testmid.c success
failure
Return code = 1
Flowcode var ude i stand til at kompilere flowchart's C kode pågrund af følgende fejl:
If dit flowchart indeholder C kode, review det nøje. Hvis dit flowchart ikke indeholder C-kode og du virkelig har reviewed koden, kontakt Teknisk
FINISHED
testmid.c
testmid.c success
failure
Return code = 1
FINISHED
