lcd 20x4 problem
Posted: Thu Mar 24, 2011 10:54 pm
I'm really busy with my project and made some good progress. Monday I have bought A new LCD screen for my project from Conrad.nl.
The LCD is an AV2040 with an KS0066 LCD controller ship on it. Thats the main reason I have bought it because the EB005 LCD board uses also an KS0066 controller. I have also bought an breadboard eblock for hooking up my LCD but because its not arrived yet I have solder some connections to the LCD and plug them into the EB005 Board into plug array P2, after checking all the connections and being sure everything is fine I turned the power on, you gues!
NO REACTION.
So I have checked the datasheet of the EB005 board I say that they used the connections 4-7 as the data pins. and I used 0-3 on my LCD. So after switch then to meet up with the connections of the EB005, I checked again this time there is something different.
First, only 2 rows where black (row 1 and 3)
now all rows are adjustable with the contrast pot.
So thats some of improvement.
But when I whant to display "Hello World" it goes fine on the LCD from the EB005 and not on my new LCD, some times ive got a bunch of random chars. but not all the time. I have taking a look on the two data sheets and checked maybe its a timing issue. There is some differences but I not sure that, that is my problem.
I also checked my clock setting XTAL and HS and disabled LVP also.
Hope you guys can help me.
Regards Jordy Kleian
NO REACTION.
