canbus programming
s.o.bakker91
canbus programming
Post by s.o.bakker91 »
I am using flowcode v4 to create a can bus communication between 2 multiprogrammers. however, it appears Flowcode v4 can't complile CAN components. When trying to compile the flowcode file to the multiprogrammer board (EB- 006-00-6) the following error appears: "this version of flowcode will only compile the following components: LED, LEDarray, led7seg, led7seg4, LCDDisplay, SWITCH, SWITCHbank, ADC, Keypad, PWM, FormulaFlowcode and MIAC."
This Flowcode version is a student version registered to Hogeschool Rotterdam. Is that the problem? Do I need the professional version for it to work?
Thank you,
Re: canbus programming
A professional or site license version of Flowcode is required to allow advanced components such as CAN to compile correctly.
Seems your school had a Pro license of Flowcode v3 but then for some reason downgraded to the Student license for version 4.
If they choose they can upgrade their license to a pro by using this link.
http://www.matrixmultimedia.com/product ... PHPSESSID=
