Hitag 2 RFID help
Posted: Sat Jun 25, 2011 8:03 am
by mrclauds
Hi everyone...
Im struggling with the rfid a little and was hoping someone could give me some guidance...
The module I am using is : http://docs-europe.electrocomponents.co ... 813104.pdf
Pic16F877A
I've gone through the examples and cant seem to make heads or tails out of it as i cant get it to work with my module...
I want to bit bang and not use the UART Rx and Tx as it is already being used for PC communications...
Could someone show me how to do it please and explain how and why is was done so I can understand it and be able to apply it to future projects?
Also, where would I find the information on what each command under rfid does?
Read UID
Read block
read buffer
Write etc...
Not sure what each one is doing exactly...
Using Hitag 2 in password mode, Please tell me if this is correct?
I must read buffer to get tag password
write buffer to reply with reader password
read block to see data on card?
Also, I was able to make a small program to read a 4001 tag with just it's ID using read buffer and then display it on a screen...
The problem is that when I put another tag over reader it still shows me the original tags ID? I must reprogram the system and shut it down to get it to read each new tag ID?
I assume this is due to the module reading the tag and keeping that data in it' own buffer and I simply read it over and over, how would I clear the modules buffer so it can pick up the new tags ID?
If someone could explain how flowcode is communicating with the chip, then I might be able to understand what is going on...
Clauds
Re: Hitag 2 RFID help
Posted: Sat Jun 25, 2011 9:06 pm
by mrclauds
I've managed to come right with regards to reading the rfid tag using lots of trial and error...
I'm still stuck with regards to using the rfid without using the chips UART though?
Am i going to have to bit bang each command individually?
Or can I still use the standard RFID macros somehow?
Clauds
Posted: Mon Jun 27, 2011 11:40 am
Hello Clauds,
You can move the RFID component to use a bit bandged serial UART rather then the standard hardware UART by using the code customization feature. Select the RFID component on the panel and then click the custom code button on the properties pane. You will need to edit the following sections of code.
Initialisation
SendRS232Char
ReceiveRS232Char
You can find examples of the code for the software bit banged operation from the RS232 component C file.
If you get stuck then attach your program to the forums and your customized component functions will be retained in the file for us to look at.
Posted: Mon Jun 27, 2011 9:46 pm
by mrclauds
Thanks Benj
I was thinking of changing the pc comms over to bit banged and keep the rfid on UART...
Is there any reason why I shouldn't?
I assume the reliability of the bit banged protocol is as good as the inbuild UART provided the coding is well done right?
If so, then it will be simpler to have comms with PC via bitbanging and RFID on UART...
Clauds
Posted: Tue Jun 28, 2011 10:09 am
Hello Clauds,
Yes that is probably a better option as the code is already there to do the bit banging for the serial comms. The bit banging code should work ok at the default clock speed of 19.6608MHz and a few others but we have modified the code for the new release to provide more accurate timing across the board. Give it a go and let me know if you have any problems.
Posted: Tue Jun 28, 2011 12:50 pm
by mrclauds
Thanks very much :)
