Stop Watch (MM:SS:DD),
Posted: Fri Jul 22, 2011 4:16 am
by armagon29
Dear All:
I made a modification from FC example “Digital clock” to become a STOPWATCH (MM:SS:DD), but I tested this FC Stopwatch with a real Casio Stopwatch and they have about 10% different between 2 times, could you help me to check time interruption options or clock speed
5. Digital stopwatch.FCF
D Stopwatch
(15.81 KiB) Downloaded 507 times
Re: STOP WATCH (MM:SS:DD),
Posted: Fri Jul 22, 2011 8:42 pm
Hi armagon29.
You can try the following two thing to make your stop watch more accurate.
1) In your INITIALISE macro, Change prescaler in your timer interrupt from 1:1 to 1:256
2) In your INTERRUPT_TMR0 macro add a C Code box with
tmr0=+64;
at the beginning.
Let me know if that works please, and if it does I will explain what the problem was.
Your flowchart counts in 100th secs, secs and minutes now.
Posted: Sat Jul 23, 2011 4:03 am
by armagon29
FC stopwatch works OK now
Posted: Sat Jul 23, 2011 12:18 pm
Your welcome, Thanks for letting us know.
I will explain what was happening for anyone wishing to learn how the timer0 side works. Then it would be easier to create/alter flowcharts that involve timer0
For a brief explernaion of timer0 interrupt including why I added
tmr0=+64;
See:
http://www.matrixmultimedia.com/mmforum ... =26&t=8660
With the original digital clock example which I have attached, if you look at the timer0 properties In INITIALISE macro (double click or right click timer0 icon and select properties), the prescaler is set for 1:128 and below it shows interrupt frequency at 150Hz.
This means that the timer0 macro is accessed once every 1/150 = (6.667ms to 3 decimal places) = 150 times a second hence 150Hz
That is why in the SECONDS macro there is a decision branch
SECOND_COUNTER >= 150
, since 6.667ms x 150 = 1 second
So each time the SECONDS macro is accessed the SECOND_COUNTER is increased by 1, and when the value reaches 150, exactly a second has passed. The name SECOND_COUNTER is a bit missleading since when this value is increased by 1 its only 6.66ms has elapsed and not 1 second!
Going to the example armagon29 posted,
is changed to
SECOND_COUNTER >= 1
Since this there is a calculation within the Yes part:
SECONDS = SECONDS + 1
then after timer0 interrupt is been accessed ONCE!this decision will then be true, both
SECONDS
and
SECONDS_UNITS
will increase by +1. Looking at the timer0 properties interrupt frequency is 19200Hz this will happen every 1/19200 = 52us. Thats why the timing is out.
Here's what I did. I decided that the timer0 interrupt should trigger every 100ms since flowchart is created so 10 x
SECONDS_UNITS
increases
SECONDS_TENS
by 1, and 10 x
SECONDS_TENS
increases Seconds by 1. Therefore since to get 1 scecond, the interrupt has to trigger 100 times. Since you want to LCD to display every 10ms like a stop watch, I have changed interrupt to the nearest lower value to 100Hz = 75Hz, and used my program posted here:
To obtain desired value for
tmr0=+64;
