pcb artwork
Posted: Mon Aug 15, 2011 12:29 pm
by rashid1
wouldn't it be nice if matrixmultimedia could intergrate some kind of pcb layout design after flowcode is designed
Re: pcb artwork
Posted: Mon Aug 22, 2011 11:00 am
We did have plans for doing something similar to this but I think we are not going to have time to develop and squeeze it into version 5. Maybe something for version 6? All of the E-block datasheet contain schematics of the boards so you should be able to build up custom circuits fairly easily.
flowcode 5 example
Posted: Mon Jul 29, 2013 11:05 am
by rashid1
this file example 1.single servo motor control is not compiling
errors
I think It does not like the targeted pic 16f88
any ideas why
Re: pcb artwork
Posted: Mon Jul 29, 2013 11:32 am
Hi rashid1,
Servo component will only work with target devices that has got at least built in 2CCP channels.
16F88 only has one, hence will not compile.
Also Servo component will only work with professional version and not the free or Student/Home version.
If you're asking about any component to do with professional version, then you must first register for the correct part of forum
You are more likely to receive a reply if posting in the correct part of the forums.
For V4 is this link:
http://www.matrixmultimedia.com/mmforum ... =29&t=8762
For V5 its this link:
http://www.matrixmultimedia.com/mmforum ... =46&t=9958
