Comments and Strings
dbasnett
Has thanked: 8 times
Been thanked: 11 times
Post by dbasnett »
Would it be possible to 'comment' out an icon? As it is now I have to delete the icon(calculation, io, if) to test what if's. In other languages commenting is a common feature.
Strings - As a newbie I am finding that working with strings can be painful when the received data(RS232) contain bytes with a value of 0.
JohnCrow
Has thanked: 364 times
Been thanked: 716 times
Re: Comments and Strings
Post by JohnCrow »
Its not possible to comment out an icon in FC, though that is a good idea :D
I can suggest two ways of getting round this, apart from deleting it.
1. You could use the jump to / connection point either side of the icon or part of flowchart you wish to remove.
2. If your flowchart finishes with a loop icon, you could always drag the icon you want to ignore to between the last loop icon and the end icon.
Both are "messy" but if only used when developing a program, shouldn't be too much of a problem.
dbasnett
Post by dbasnett »
I hadn't thought of the connection icon, the go around method. I'll remember that if the Matrix folks don't add a 'Comment' feature. BTW - I like your compass.
DavidA
Has thanked: 58 times
Been thanked: 258 times
Post by DavidA »
A "comment out" feature might work well, sort of disables that icon, will mention it!
JonnyW
Has thanked: 63 times
Been thanked: 290 times
Post by JonnyW »
Hi there. We have been toying with a couple of possibilities since this was suggested and it works quite well! I doubt you will need to use a goto icon in FC5. Thanks for the suggestion.
Jonny
Spanish_dude
Been thanked: 102 times
Post by Spanish_dude »
I don't know how you did it, but you could do it for multiple icons at once, like when you select an icon or a group of icons and then left clicking you'll see a disable icon(s) option ?
JonnyW
Post by JonnyW »
Hi Nicolas. Yeah, thats the idea. The final version would hopefully work similar to the screenshot. This shows the menu item and some disabled icons too.
Disabled icons
Disabled icons
Jonny
dbasnett
Post by dbasnett »
That is exactly what I was thinking.
