PIC10F200 missing files
Posted: Fri Sep 02, 2011 8:11 am
by barryw
Hi I have just updated my Flowcode V4 and have selected a PIC10F200, came to compile to hex and got report that, boostc/include PIC10F200 file missing,
will please direct me to a download of the PIC10F include files.
Many Thanks
BarryW
Re: PIC10F200 missing files
Posted: Fri Sep 02, 2011 8:19 am
Hello Barry,
I'm afraid that the default BoostC compiler does not currently support the 10F devices. You can use them by doing the HiTech workaround which is detailed below.
http://www.matrixmultimedia.com/mmforum ... =26&t=6812
Posted: Tue Sep 06, 2011 2:32 pm
by barryw
Have setup the HI-TECH compiler and now get error message
Launching the compiler...
C:\Program Files\HI-TECH Software\PICC\9.70\bin\picc.exe --CHIP=10F200 -N48 Kojak1.c
Kojak1.c: main()
56: osccal = osccal & 0xFE;
^ (192) undefined identifier "osccal"
89: gpio = (gpio & 0xfb) | 0x04;
^ (192) undefined identifier "gpio"
107: gpio = (gpio & 0xfb) | 0x04;
(1273) Omniscient Code Generation not available in Lite mode (warning)
HI-TECH C Compiler for PIC10/12/16 MCUs (Lite Mode) V9.70
Copyright (C) 2009 Microchip Technology Inc.
(908) exit status = 1
Return code = 1
Flowcode was unable to compile the flowchart's C code due to the following errors:
If your flowchart contains C code, please review this carefully. If your flowchart contains no C-code or you have thoroughly reviewed the code, contact Technical Support.
How do I work round this, it looks as if the compiler dont want to play.
Many Regards
Barry
Posted: Tue Sep 06, 2011 2:43 pm
Hello Barry,
Hm that's odd it appears that the definitions for the 10F devices have not come through correctly.
To work around this click the View -> Project Options menu.
Next enable supplementary code by clicking the check box and then click the edit supplementary code button.
Paste the following two lines into the top pane of the supp code window.
#define osccal	OSCCAL
#define gpio	GPIO
Then click OK and your program should now compile correctly.
Let me know how you get on.
Posted: Tue Sep 06, 2011 2:58 pm
by barryw
Many thanks for that.
That worked for the OSCCAL and GPIO OK but now get this :-
C:\Program Files\Matrix Multimedia\Flowcode V4\FCD\internals.h: 176: (1360) no space for auto/param delay_ms@del
Return code = 1
It Dont seem as if the delay is reconised
Posted: Tue Sep 06, 2011 3:09 pm
The message.
Means that there is not enough room left on the device for the delay function to fit into memory.
Unfortunately the 10F devices have very little memory and it seems they are designed for a very small amount of tight assembler code and not really suitable for C code. If your struggling to reduce the size of your program then the larger memory 10F devices should work correctly for you.
Posted: Tue Sep 06, 2011 3:26 pm
by barryw
Many Thanks for that, I will try a larger device.
Barry W
