[solved] Timing - using TMR2
Posted: Sat Sep 17, 2011 2:13 pm
by dbasnett
TMR2 is set up to fire 100 times per second and the interrupt routine simply sets a flag that is handled in the main loop. In the main loop I calculate tenths of seconds, seconds, hours, days, nothing fancy. (add value, check rollover unit, if rollover increment next unit and reset, etc.)
Over the course of 24 hours the program gains about 10 seconds, compared to the clock on my PC. The clock on my PC is updated via the internet daily.
I just wanted to confirm that this is 'normal'. Thanks in advance.
Re: Timing - using TMR2
Posted: Sat Sep 17, 2011 4:50 pm
by Jan Lichtenbelt
Dear dbasnett,
What is normal? That the PC updated the clock with internet? Although my PC says it does, in practice it doesn't. I have to do that manually.
Or is the 10 seconds/day deviation as expected for the accuracy of the crystal used?
Kind regards
Jan
Posted: Sun Sep 18, 2011 8:47 am
If you would like to post your flowchart, then I can look at it for you.
I would expect the time to be more accurate than that, Epically using an external crystal.
Posted: Wed Sep 21, 2011 1:05 pm
by dbasnett
My question is if I have TMR2 set to fire 100 times per second, how accurate will it be over long periods of time? In other words, does it fire exactly 100 times per second or about 100 times per second(i.e. 99.9 times per second)?
Posted: Wed Sep 21, 2011 4:04 pm
by Sean
The standard xtals used have a typical tolerance of +/-50ppm. This affects all operations in the microcontroller and could directly contribute nearly 4.5 seconds of drift within a counter/timer over a 24 hour period (86400 seconds).
The load capacitors used in the oscillator circuit also have 'typical' values, but may mot be a perfect match for an individual xtal, resulting in additional frequency drift. Your figures indicate a total drift of approximately 115ppm.
There are higher specification xtals, and more advanced oscillator circuits, that could produce a more accurate and stable clock frequency if required.
Posted: Wed Sep 21, 2011 4:28 pm
Most RTC applications use a low frequency 32.768KHz watch crystal. These use the same low cost standard tolerance crystals but because they are running at a much lower frequency the ppm error becomes much more negligible.
20MHz crystal with +/- 50ppm error : Max error = 20 x 50 = 1KHz which equates to +/- 8640 clocks per 24 hours.
32.768KHz crystal with +/- 50ppm error : Max error = 0.032768 x 50 = 1.6384H which equates to +/- 10 clocks per 24 hours.
Me and Sean are at odds on this, though I remember investigating this at college so hopefully I'm not far off.
Posted: Wed Sep 21, 2011 4:47 pm
by dbasnett
Thanks. I was just looking for confirmation, which you have both provided. I am gaining about 10 seconds / 24 hours which means that the clock is 99.988% accurate.
Re: [solved] Timing - using TMR2
Posted: Tue Sep 27, 2011 11:25 am
by dbasnett
Added code to adjust the clock by hundredths of a second per hour. This fixed the drift.
Posted: Fri Nov 11, 2011 3:39 pm
by dbasnett
I learned something about the time on my PC when I noticed that the clock on the EB006 was off by several seconds after re-booting my PC. The details are here
http://social.msdn.microsoft.com/Forums ... 05a49365a1
