Programmer settings for JTAGICE_MKII ISPMode
Posted: Thu Nov 03, 2011 8:09 pm
by Niro
Dear all,
i was reading a lot of posts and tried to edit the programmer settings (..Chip/Compiler Options) also as the avrc.bat file but nothing worked out.
Could anybody help me to make Flowcoe work with my JTAGICE_MKII (USB, ISP mode)?
Many Thanks,
Niro
Re: Programmer settings for JTAGICE_MKII ISPMode
Posted: Fri Nov 04, 2011 7:02 pm
by Sean
We haven't used the JTAGICE, but here is a verion of the avrc.bat file that has been modified using the AVRDUDE and AVR Studio documentation:
avrc_jtagice2isp.zip
(788 Bytes) Downloaded 328 times
The following changes have been made to the top lines of the batch file.
@SET Programmer=jtag2isp
@SET DUDEPort=usb
@SET STKPort=USB
@SET STKPath="C:\Program Files\Atmel\AVR Tools\JTAGICEmkII\jtagiceii.exe"
I would suggest starting with the AVRDUDE option. If you have already used the JTAGICE from AVR Studio, it might be using a USB driver that is incompatible with AVRDUDE. The AVR Studio options can be selected by changing AVRDUDE to STK500 in the Flowcode Chip -> Compiler Options -> Programmer: Parameters list.
The path for jtagiceii.exe assumes a default installation and might need to be modified in the batch file.
If the AVR Studio option is required, the parameter list and batch file might require further modification.
Posted: Mon Nov 07, 2011 7:57 pm
by Niro
Dear Sean,
this works really great!!!
Once again, many thanks!!
Niro
