Does anybody know if...
Posted: Tue Nov 08, 2011 3:29 pm
...there's a fault on the latest USB HID Drivers that requires an updated Flowcode definition please?
The USBHID (Macro), specifically the SendDataDirect setting continues to do what it says irrespective of any following code.
It seems to get locked in a loop somehow. So a keypad press does indeed transmit the variable's scancode (yes it's still that keyboard thing!) correctly but on a Flowchart where I sequentially do:
1. Send the variable's scancode with the SendDataDirect setting using the USBHID Macro - that's fine.
2. Light an LED.
3. Pause for 10 seconds.
4. Send a different variable's scancode with the SendDataDirect setting using the USBHID Macro - that's fine.
Except the SendDataSetting keeps repeatedly sending the variable in a constant loop forever despite the 10 second delay whereas it used to send in once previously.
It keeps sending until point 4 where it reads and sends the next scan code.
Is there a fault in this routine does anyone know or what am I doing wrong please?
2. Light an LED.
