FAT16 and breakout board form adafruit
Posted: Thu Nov 17, 2011 8:36 pm
by Jordy101091
Hi, all
Today I have recieved my micro SD card breakout board from adafruit.
I have connected everything correctly
CLK to port.A - 2
CS to port.A - 0
Data in portA.- 4
Data out port.A - 5
I started with the following macro's:
Init_FAT inside a loop (Until MMC_start = 0) --> when 0 init is OK
after that loop I use macro:
Create_file String "Test.txt"
I suspect when I insert the micro sd into my computer that a file has been created, but nothing.
I have also connected it to the hardware SPI but same result
I really dont know what Im missing or doing wrong hope somebody can explane and help me solve this.
Regards Jordy
Re: FAT16 and breakout board form adafruit
Posted: Fri Nov 18, 2011 11:34 am
Hello Jordy,
Looks like a nice little breakout board.
Can you tell me which version of Flowcode your using? I would recommend updating to v4.5 if you have not already done so.
I would also check that the card is formatted correctly for either FAT16 or FAT32 depending on the settings you are using in Flowcode.
You can use a program called winhex to view the contents of the card and this will show you if any data has been added to the card.
For some slower cards you could try increasing the existing delay or adding a extra delay to the SPI_Byte macro using code customisation. I think this has fixed the problem for other users.
If your struggling to get this working then please attach your Flowcode file and I will give it a once over for you.
Posted: Fri Nov 18, 2011 6:20 pm
by Jordy101091
Hi Benj,
I have updated to version 4.5 and have created a simple loop in the main program to init the micro SD card with a small delay in it.
But it keeps hanging on waiting for MMC Card.
I dont know what the problem is.
I post my flowchart here
Regards Jordy
Posted: Sat Nov 19, 2011 3:40 pm
by Jordy101091
Hi benj,
Do I need to use pull-up or pull-down resistors on my DO-DI and CS pins.
Posted: Sat Nov 19, 2011 5:02 pm
by Jordy101091
Benj,
I have attached a couple of pictures of what the output is on my scoop
Output signal on CLK pin (Clock)
Output signal on the DO pin (Data Out)
The signal on the datain is something like a sawtooth figure.
When the timebase stands about 20ms and volt per div of about 20mV
Hope you can help me whit this.
Regards Jordy
Posted: Sun Nov 20, 2011 8:13 pm
by Jordy101091
Hi, Benj
I Finally got it working, the problem was that I have twisted the data in and data out lines. So i connected it wright and it al works perfectly.
I can even wright data into my .csv file.
I'm hoping that you can help me one more time to do the following thing:
So the goal here is to make a datalog of these items.
Light, Temperature, pH
These thing needs to come in one file that I have pre-made in excel. The flowcode program only needs to fil the missing data.
After the collection of data is completed I need to plug the card into my PC and open the excel sheet and wright away seeing the different graphs.
(see the example file)
I'm hope that this even possible, if its not. Can you give some options that I can do to make this work.
Regards Jordy
Posted: Mon Nov 21, 2011 10:00 am
by Steve
Adding data directly to a pre-made XLS file might be tricky because the file format is proprietary and complex. Adding data to a text-only CSV file is easier, but you would lose the graph.
A way around this might be to have an XLS spreadsheet (with graphs) look at an external CSV file for its data - search the Excel help file for "linked data" or "external reference".
Posted: Mon Nov 21, 2011 10:22 pm
by Jordy101091
Hi, Benj or Steve,
I have something on my mind that I want to build for my project but I have one problem.
I dont know how to program a windows based program.
My Idea is as follow.
With my flowcode program, I want to create one or more log files for each item: Light Level, Temperature ect.
Lets say I'm creating 4 log-files for each item: Light, Temp, pH and time & Date.
My Idea was, that some how create A windows program that can load-up these files and display them on one side of the screen with all the contents and on the other side, show the different graphs.
And to store that data and give it is own name so you can select witch log you want to see, from a week ago ore a few days, something like that.
I appreciate any effort to help me.
Regards Jordy Kleian,
PS. Or you guys have better solution for this I really want to hear it.
Posted: Tue Nov 22, 2011 9:27 am
by Steve
There are a few ways you can do this. For example...
You could have a HID USB program that pretend to be a keyboard. On your PC, load the Excel file with the graphs and click on the first cell of the data. Then press a button on your hardware, which will then send out the appropriate data as if you were typing it in.
Another way is to use our Internet E-block and create a webpage that retrieves the data and displays it in a browser (you'd need some web programming skills for this).
Or create a program that does everything in hardware without the need for a PC. We have a new VGA E-block coming out soon that will give you an appropriate screen size and resolution for this.
I hope these ideas help.
Posted: Tue Nov 22, 2011 12:08 pm
by Jordy101091
mmh, sorry steve,
Im a little disapointed that there is no other way around this problem.
I'm afraid that the internet webpage solution is not a good idea because I dont have much space left on my microcontroller.
The idea of an windows based program is that even possible to make.
do you have any more ideas on how to display the logged data graphicaly.
Regards Jordy
Posted: Tue Nov 22, 2011 2:18 pm
by Steve
Is the first idea (USB HID program generating a virtual keyboard input) not ok for you? I think there's even an article about this approach in our learning centre.
Posted: Tue Nov 22, 2011 2:56 pm
by Jordy101091
Hi steve I will look into this article, seems to me the most aceptable to try.
With the FAT16 component, when you create a text file (.txt) is it possible to go go down 1 line. just like if you would hit enter on you're keyboard.
I want to try one more thing with this component, I hope that I can create this kind of format:
63, 19:20
65, 19:21
66, 19:22
64, 19:23
I think I know how I'm going to get the 19:20 in one string but I need to know if I can go down one line in the text file.
does it have anything to do with this:
Move_To_Next_File_Sector
If this is all possible then I'm happy and the problem is gone. 8)
regards Jordy
Posted: Tue Nov 22, 2011 3:40 pm
by Steve
You need to add the characters "carriage return" (0x0D) and "line feed" (0x0A) to the end of each line in your string.
Posted: Tue Nov 22, 2011 8:35 pm
by Jordy101091
Hi steve verry verry thanks for your comment.
But I have one question.
How do I ad these at they end of my string:
I have tryed this: datalog1 = datalog1 + "*" I dont think its right. Can you help me out.
jordy Kleian
Posted: Wed Nov 23, 2011 10:01 am
by Steve
This should do the trick:
s = s + "\r\n"
