Problem compiling C code "Errors"
Posted: Sat Nov 19, 2011 4:41 am
Hi Guys, Everything is working great in simulator however when I try to compile to my chip (16F877A) I am getting errors. This may be one for you Ben? The c file is below. I pulled up the C file in Visual Studio and found errors on lines 611,603,718,710,836,883 and there may be more? I think these errors are all related? This is what Flowcode is showing me:
F:\Wire Cutter\work5.c(631): error: missing semicolon
F:\Wire Cutter\work5.c(566): error: failure failure Return code = 1 Flowcode was unable to compile the flowchart's C code due to the following errors:
The line numbers that Flowcode gives me never seem to be correct? Is it because the Flowcode line numbers are without any blank lines? I was wondering about it?
As always any help is greatly appreciated!!
Werner
Werner
