RS232 with different baud rates
Posted: Fri Dec 09, 2011 11:54 am
by Jan Lichtenbelt
I want to use RS232 with starting at 38400 baud rate. But later on in the program I want to change the baud rate to 19200. How can I realise that?
Kind regards
Jan Lichtenbelt
Re: RS232 with different baud rates
Posted: Fri Dec 09, 2011 9:49 pm
by Dan81
Hello Jan
That is for a Hardware solution.
When you want to change the baud rate :
Put a 'C code" icon with :
spbrg = ?? ;
If you want to know the value of ?? :
With the right value of the Quartz frequency. (19.66MHz for a Matrix board)
In the RS232 properties : choose 19200
then
- Chip / Compile to C
- Chip /View C
- search : " SPBRG_VAL "
- the answer will be something like :
. #define RS232_8520508_SPBRG_VAL 69 (here for 19.66MHz)
- replace ?? by your value (here 69)
Then put again 38400 in the RS232 properties.
Be sure that all datas have been sent before changing "spbrg"
Daniel
Posted: Sat Dec 10, 2011 8:38 pm
by Jan Lichtenbelt
Dear Daniel
Thanks a lot. This made me to start to look more in detail RS232.
I found the follwoing:
1) The Baud Rate Generator SPBRG can be calculated from the figure below (from datasheet of 12F1840)
2) The High Baud Rate Select bit (bit2 of TXSTA register) must be set for baud rates >= 4800. In that case set in C-code: txsta= 0x04; else txsta=0;
3) In my case I found an other difference in the bitbanched baud rates. The bitbanched BAUT Rate Delay is for baud rate >=2400 equal to 998400/baudrate. (for baudrate 1200 this delay is 833). How to change this value in C-code is not clear to me. Perhaps changing the value RS232_66470_SW_BAUD, but I do not know what the meaning is of 66470 values and if this one does not change in other applications (microcontrollers).
Kind regards,
Jan
