Component: LCD Base (Alphanumeric)
Version 2.5
Category Alphanumeric
LCD Base component
Generic configurable alphanumeric LCD display component based on the standard Hitachi HD44780 controller IC wiith selectable 4/8 bit interface
Please click here to download the component source project: FC_Comp_Source_LCD_Base.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_LCD_Base.fcfx
For the LCDs to work with the Flowcode LCD component they need to be connected up in 4-bit data mode.
The 4 data signals actually go to the upper data nibble on the LCD as shown below.
Displaying a numeric value
The LCD will retain the contents of the display, for high speed data we only want to have to write to the portion of the display that can change. FC6 Icon.png LCD Demo
Clear
Fc9-comp-macro.png Clear
ClearLine
Fc9-comp-macro.png ClearLine
Fc9-u8-icon.png - BYTE Line
The line to clear, zero being the first (top) line of the display
Command
Fc9-comp-macro.png Command
Fc9-u8-icon.png - BYTE instruction
Send a defined command to the LCD Screen. See datasheet for supported commands.
Cursor
Fc9-comp-macro.png Cursor
Fc9-u8-icon.png - BYTE x
Set the cursor position in the X plane, 0 is the left most cell
Fc9-u8-icon.png - BYTE y
Set the cursor position in the Y plane, 0 is the top most cell
PrintAscii
Fc9-comp-macro.png PrintAscii
Fc9-u8-icon.png - BYTE character
Holds an ascii value.
PrintFloat
Fc9-comp-macro.png PrintFloat
Fc9-f32-icon.png - FLOAT Number
Fc9-u8-icon.png - BYTE DecimalPlaces
PrintFormattedNumber
Fc9-comp-macro.png PrintFormattedNumber
Fc9-u32-icon.png - ULONG Number
Fc9-bool-icon.png - BOOL Format
0=Signed, 1=Unsigned
Based on v5 macro, will allow you to print a number. This is limited to a signed-INT, -32768 to 32767
Fc9-s16-icon.png - INT Number
PrintString
Fc9-comp-macro.png PrintString
Enter the text or variable to print to the LCD
RAMWrite
Fc9-comp-macro.png RAMWrite
Fc9-u8-icon.png - BYTE Index
Values 0 to 7
Fc9-u8-icon.png - BYTE d0
Fc9-u8-icon.png - BYTE d1
Fc9-u8-icon.png - BYTE d2
Fc9-u8-icon.png - BYTE d3
Fc9-u8-icon.png - BYTE d4
Fc9-u8-icon.png - BYTE d5
Fc9-u8-icon.png - BYTE d6
Fc9-u8-icon.png - BYTE d7
RawSend
Fc9-comp-macro.png RawSend
Sends data to the LCD display
Fc9-u8-icon.png - BYTE data
The data byte to send to the LCD
Fc9-bool-icon.png - BOOL type
A boolean to indicate command type: true to write data, false to write a command
RemapCharacter
Fc9-comp-macro.png RemapCharacter
Assigns a remap character allowing the PrintString function to automatically swap between pre-defined characters. The characters can be custom (in the range 0-9) or can point to an existing character in the LCD character map.
Fc9-u8-icon.png - BYTE RemapIdx
Remap Index, Range: 0 to (Remap Characters - 1)
Fc9-u8-icon.png - BYTE SearchCharacter
Character to look for a replace
Fc9-u8-icon.png - BYTE ReplacementCharacter
New character value to use in place of the search character.
ScrollDisplay
Fc9-comp-macro.png ScrollDisplay
Fc9-u8-icon.png - BYTE Position
Holds the number of positions to shift the display
Fc9-u8-icon.png - BYTE Direction
0 = left, 1 = right
Start
Fc9-comp-macro.png Start
Startup routine required by the hardware device. Automatically clears the display after initialising.
Fc9-type-16-icon.png Interface mode
Choose between 4-bit mode, 8-bit mode and 8-bit mode using a port instead of individual pins to improve code efficiency.
Fc9-type-5-icon.png Data 0 (11 / 7)
Data pin 0 - Connects to Data 4 on the hardware in 4-bit mode or Data 0 in 8-bit mode
Fc9-type-5-icon.png Data 1 (12 / 8)
Data pin 1 - Connects to Data 5 on the hardware in 4-bit mode or Data 1 in 8-bit mode
Fc9-type-5-icon.png Data 2 (13 / 9)
Data pin 2 - Connects to Data 6 on the hardware in 4-bit mode or Data 2 in 8-bit mode
Fc9-type-5-icon.png Data 3 (14 / 10)
Data pin 3 - Connects to Data 7 on the hardware in 4-bit mode or Data 3 in 8-bit mode
Fc9-type-5-icon.png Register Select (4)
Register Select Pin - Informs the display if a command or data is about to be sent.
Fc9-type-5-icon.png Enable (6)
Enable pin - Used to synchronise data writes to the display
Fc9-type-7-icon.png Use Read/Write Pin
Set to "true" if the displays R/W pin is not hard wired. Set to "false" if the R/W pin is wired to ground.
Fc9-type-21-icon.png Remap Characters
Used to allow characters to be replaced with alternate characters. Custom characters or characters from the LCD memory map can be used as replacements. Each replacement consumes two bytes of RAM memory and is applied automatically when printing strings.
Fc9-conn-icon.png Display Settings
Fc9-type-16-icon.png Rows
Number of lines of characters the LCD can display.
Fc9-type-16-icon.png Columns
Number of characters the LCD can display on a single line.
Fc9-conn-icon.png Simulation
Fc9-type-7-icon.png Show Background Elements
Show or hide features like the title and background.
Fc9-type-15-icon.png Component Label Scale
Fc9-type-1-icon.png Text Colour
Colour of the font characters drawn on the display
Fc9-type-1-icon.png Text Background
Fc9-type-1-icon.png Display Background
